Hello,
I can't install my capture card pinnacle miro dc10 with fedora 8.
when I scan pci ports :
but with "camstream", the card doesn't appear. The kernel is 2.6.25.4-10.[root@wiking Nicolas]# /sbin/lspci
00:00.0 Host bridge: nVidia Corporation nForce2 IGP2 (rev c1)
00:00.1 RAM memory: nVidia Corporation nForce2 Memory Controller 1 (rev c1)
00:00.2 RAM memory: nVidia Corporation nForce2 Memory Controller 4 (rev c1)
00:00.3 RAM memory: nVidia Corporation nForce2 Memory Controller 3 (rev c1)
00:00.4 RAM memory: nVidia Corporation nForce2 Memory Controller 2 (rev c1)
00:00.5 RAM memory: nVidia Corporation nForce2 Memory Controller 5 (rev c1)
00:01.0 ISA bridge: nVidia Corporation MCP2A ISA bridge (rev a3)
00:01.1 SMBus: nVidia Corporation MCP2A SMBus (rev a1)
00:02.0 USB Controller: nVidia Corporation MCP2A USB Controller (rev a1)
00:02.1 USB Controller: nVidia Corporation MCP2A USB Controller (rev a1)
00:02.2 USB Controller: nVidia Corporation MCP2A USB Controller (rev a2)
00:04.0 Bridge: nVidia Corporation MCP2A Ethernet Controller (rev a3)
00:06.0 Multimedia audio controller: nVidia Corporation MCP2S AC'97 Audio Controller (rev a1)
00:08.0 PCI bridge: nVidia Corporation MCP2A PCI Bridge (rev a3)
00:09.0 IDE interface: nVidia Corporation MCP2A IDE (rev a3)
00:0b.0 IDE interface: nVidia Corporation nForce2 Serial ATA Controller (rev a3)
00:1e.0 PCI bridge: nVidia Corporation nForce2 AGP (rev c1)
01:00.0 VGA compatible controller: nVidia Corporation NV5M64 [RIVA TNT2 Model 64/Model 64 Pro] (rev 15)
02:06.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:06.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
02:07.0 Multimedia video controller: Zoran Corporation ZR36057PQC Video cutting chipset (rev 01)
02:08.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)
02:08.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)
02:08.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 62)
02:08.3 FireWire (IEEE 1394): VIA Technologies, Inc. IEEE 1394 Host Controller (rev 46)
02:09.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8029(AS)
02:0a.0 SCSI storage controller: Adaptec AHA-7850 (rev 03)
and :
Despite the kernel contains this module !!!![root@wiking Nicolas]# /sbin/modprobe zr36057
FATAL: Module zr36057 not found.
What can I do?
Thread: Miro DC10 + Fedora core 8
There's the relevant info on the capture card
Here's the order to load the zoran driver for a DC 30
Also before modprobe-ing, do both an dmesg | tail to see if there are any errors after a fresh boot. Then lsmod to see if the module is even loaded.Code:modprobe vpx3220 modprobe adv7175 modprobe zr36016 modprobe zr36050 modprobe zr36067
Better help could be gotten from the mjpeg mailing list. https://lists.sourceforge.net/lists/...fo/mjpeg-users (the mjpeg-tools project handles the zoran capture driver)
You could also check your kernel config to make sure the zoran driver IS in fact either enabled. It's under Device Drivers -> Multimedia Devices -> Video for Linux -> Video capture adapters -> Zoran ZR36057/36067 Video For Linux.
Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
Your last picture is very nice.
which rpm can I install to have this one?
Fedora 8
thanks
from a command line -
su
password
cd /usr/src/linux
make oldconfig && make xconfig
It's the built in qt interface to custimize and compile your kernel. Needs the kernel sources.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
Sorry but I am newbee. Where can I download kernel sources? with yum?
thx a lot
Great !!! I have finally linux kernel configuation with qt. thxOriginally Posted by bmw524
But miro dc10 doesn't fit with v4l. It doesn't appear with camstream in spite of my miro pctv studio do it.
I very sad ....
Core 2 Duo VS Core 2 Quad
By vid83 in forum ComputerReplies: 21Last Post: 1st Sep 2009, 21:41 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 14:54 -
Intel Core 2 Quad 9550 or Core 2 Duo 8600 for games...
By retroborg in forum ComputerReplies: 11Last Post: 11th Oct 2008, 21:23 -
Intel Slashes Quad-core, Dual-core Processor Prices
By louv68 in forum Latest Video NewsReplies: 0Last Post: 22nd Apr 2008, 18:14 -
AMD 4200+ Single Core to Dual-Core Upgrade Issue...
By Bodyslide in forum ComputerReplies: 7Last Post: 30th Nov 2007, 15:45
