VideoHelp.com Forum
    I have recently purchased AT&T Uverse. I will record movies to my DVR. After that I try to record these onto a DVD with my Philips DVD recorder--dvdr 3475. When I had Direct TV through AT&T, I had no problems with dvd recording. However, every now and then I can't seem to record DVDs when I record movies to my DVR. I get the message "This program is not recordable in +VR mode." I have been able to record some movies; however, here lately I can't. I am using Memorex DVD+RW DVDs. What can I do to be able to record movies again?
  2. Member hech54's Avatar
    What you are attempting to record is either Pay Per View or heavily DRM'd stuff like Cinemax....there is nothing you can do about it legally.
    Try to use a DVD+R.
  4. Member Krispy Kritter's Avatar
    You could also try "video mode" instead of "VR mode". Otherwise, hech54 is likely correct.
    Google is your Friend
    I could not record a number of AT&T Uverse channels on my Toshiba DVD recorder , but I also have a Lite-On LVC-9016G recorder that does allow recording . Today I discovered that when the Uverse signal is routed thru the LVC-9016G I can then record on the Toshiba .
  1. can not record in +vr mode
    By bad channel in forum Capturing
    Last Post: 26th Jul 2011, 08:48
  2. Replies: 7
    Last Post: 13th Feb 2011, 12:21
  3. Replies: 21
    Last Post: 21st Jan 2011, 08:28
  4. Advantages of ripping in File mode over ISO mode...
    By hiimbored in forum DVD Ripping
    Last Post: 5th Jun 2008, 15:27
  5. My tapes will not record the full 240 Minutes in LP mode..
    By BigDan8 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 9th Mar 2008, 07:21
