VideoHelp.com Forum
    I'm converting mpeg-1 muxed files to DV or mpeg4 format so iMovie can read the soundtrack. It won't read the sound on muxed files. When I convert using ffmpegX, it appears successful,but importing to iMovie I get "Quicktime can't parse" errors.
    Also, in finder, the converted files show 0 KB in size.
    Can I get some advice?
  2. Explorer Case's Avatar
    I suppose you know why applications would error out on trying to parse 0 KB files...
    Please post the Process Information log to see what went wrong.
    Here's what seems to be called the Terminal Bash:
    Next to last line indicates "codec type mismatch"
    Any help?
    Thanks, Jeff
    Last login: Sun Jun 22 10:18:50 on ttyp1
    Welcome to Darwin!
    iMac:~ admin$ /Applications/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/pbpaste | sh
    Encoding started on Sun Jun 22 10:18:53 CDT 2008
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads --enable-x264
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    built on Apr 15 2006 08:41:02, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
    Input #0, mpeg, from '/Volumes/MacExternal1/MOVIES/FirstGradeLastDay/MOV03596.MPG':
    Duration: 00:00:46.7, start: 0.070000, bitrate: 10483 kb/s
    Stream #0.0[0x1c0]: Audio: mp2, 32000 Hz, mono, 64 kb/s
    Stream #0.1[0x1e0], 30.00 fps(r): Video: mpeg1video, yuv420p, 640x480, 104857 kb/s
    Codec type mismatch for mapping #0.0 -> #0.0
    iMac:~ admin$
  4. Explorer Case's Avatar
    Your source file has the audio stream (#0.0) mapped before the video stream (#0.1). This is reverse from what the ffmpeg engine expects. You may fix this "Codec type mismatch for mapping"-error by indicating that the streams are reversed. To do so, check the "Invert mapping" checkbox in the audio tab.
  1. parse ts pcm stream
    By niror in forum Audio
    Last Post: 2nd Oct 2011, 01:36
  2. What does this .d2v parse tell me?
    By fatcharlie in forum Newbie / General discussions
    Last Post: 10th Mar 2011, 17:13
  3. When does SUPER parse video files?
    By yoda313 in forum Video Conversion
    Last Post: 28th Mar 2010, 18:16
  4. MPEG 1 - Can't parse stream
    By Fr3d in forum Programming
    Last Post: 18th Oct 2009, 19:20
  5. Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
    By jglass in forum Newbie / General discussions
    Last Post: 15th Jun 2008, 20:51
