I have a mov file with an audio track. I'm unable to convert the file to flv if I check the encode audio box. It doesn't matter which audio codec I pick. The result is always an empty file. If I uncheck the encode audio box it converts the video to flash, but of course without sound. I also tried adding audio from an mp3 file; this also results in an empty file if I try to encode the audio.
For the record, I'm not that advanced a user. I've seen a lot of command line solutions that involve terminal. It's beyond me, I'm sorry to say. I need something "For Dummies," like a GUI oriented solution.
With the .mov file opened in QuickTime Player, do a Cmd-I (Show Movie Inspector). The Movie Inspector should list which video codec and audio codec are used. Please tell us those codecs.
Also, the left side of the Summary tab in ffmpegX should tell some details on the video and audio in the source file.
convert .mov or vob file to .flv
By Giacomo in forum Video ConversionReplies: 5Last Post: 3rd Feb 2011, 12:03 -
Trying to convert .mov to .flv - aspect ratio problems
By Graeck in forum ffmpegX general discussionReplies: 12Last Post: 21st Oct 2010, 17:55 -
convert mov to flv zero bites
By drica in forum ffmpegX general discussionReplies: 46Last Post: 30th Aug 2009, 13:42 -
Problem trying to convert .flv to .mov
By herdofcaribou in forum ffmpegX general discussionReplies: 7Last Post: 10th Feb 2008, 01:16 -
more info on no sound problem with mov to flv
By chrishawaii in forum ffmpegX bugs and suggestionsReplies: 0Last Post: 17th Aug 2007, 16:32
Statistics
Newest guides
Latest tool updates
New media comments
