VideoHelp.com Forum
Results 1 to 17 of 17
    Dear All,
    I am just starting to use hcenc and found the hcbatchgui for linux very helpful for this.Thank you for such a nice program.
    Up until a few days ago I have only used linux video tools, however, some people were saying that hcenc could beat any linux video editing methods. I decided to try hcenc and then compare.
    I am using the latest linux sidux and the latest wine that comes with it. I was not able to encode my dv home movies with hcenc until I followed a thread I believe on this forum. Someone said to install another video program which would supply some needed codecs. That worked. The problem is , I get a picvideo and www.jpg.com on every frame. I really want to use the free panasonic or another good free one. How can I get hcenc to use other dv codecs of my choice?
    Any help will be greatly appreciated.
    Thank you.
    Marcia
  2. i am using the same distro and got the same problem...
    i have "manually" installed the cedocida dv codec in this way
    unzip the cedocida20.zip
    copy the cedocida.dll in your /$HOME$/.wine/drive_c/windows/system32
    when in system32 press F4 (or go in terminal from this window)
    Create a reg file as this (name it cedocida.reg)
    REGEDIT4
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\drivers.desc]
    "cedocida.dll"="Cedocida DV Codec"
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\drivers32]
    "vidc.dvsd"="cedocida.dll"
    then launch from system32 terminal:
    regedit cedocida.reg
    you hcenc will see the dv files when passed as avs script like
    avisource("test.avi")
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
  3. Man of Steel freebird73717's Avatar
    Originally Posted by aicram
    Dear All,
    Glad you like it Marcia. In addition to buzzqw's method you might try this.
    To install a DV codec:
    1) download the Panasonic DV codec.
    2) copy the .inf & .dll file to the [wine windows directory]/inf/ directory
    3) use a console a change to the above directory by typing type cd ~/.wine/drive_c/windows/inf
    4) then execute "wine rundll32.exe setupapi.dll,InstallHinfSection DefaultInstall 128 PANADV.INF"
    Got the above information from this page at the wine app database.
    Hope it helps.
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
  4. @freebird73717
    i have tryed a very similar setup.. and failed .. that's why i have suggest a more "manual" way
    thanks!
    BHH
  5. Man of Steel freebird73717's Avatar
    Hmm. Thats wierd. Worked fine for me. Oh well. At least she will have a couple of alternatives to try.
    Always good postin with ya buzz!
    Thank you both very much for your instructions. I tried the manual one first and got an error message that regedit4 is not found. I only have regedit. Should I substitute just regedit in your code? I am a novice with wine.
    freebird73717, If I use your method how would I substitute the cedocida codec correctly? Or is the panasonic dv codec better?
    Thank you very much buzzqw and freebird73717 for your rapid and great instructions. I am sure I will get this to work soon.
    Sincerely,
    Marcia
  7. regedit4 ?
    the regedit4 and all the rest is to copy in a file (like cedocida.reg)
    and from shell is to launch
    best regards
    BHH
  8. Man of Steel freebird73717's Avatar
    Not sure how you would substitue the cedocida codec into the method I described. I haven't tried to install that codec before. The only main difference that I know of between the two is that cedocida is open source and panasonic is not.
    I'll also try to help you with buzz's method as well. Copy the text in blue from buzz's post to a text file and save it to cedocida.reg in your /home/your_user_name/.wine/drive_c/windows/system32 directory.
    Next open terminal. type cd ~/.wine/drive_c/windows/system32
    then type regedit cedocida.reg
    Buzzqw already said all this but hopefully this makes it clearer. Buzz is a smart guy. I didn't know you could edit wines registry like that. Man I love linux!
    Good luck Marcia!
    Have a good one Buzz!
    Thank you both for your replies. I totally misunderstood how to do the text file first and then the command. I believe I understand it now. When I get a chance to get back to my desktop later I will try this. I will let you know the results.
    Thank you again for such great instructions. I have to admit I would not have known the first thing about doing any of this without your help.
    Sincerely,
    Marcia
  10. sorry aicram, i must admin that my english isn't fluent as i want (or as my first language)
    the SmallVille gui ( , btw Superman is my preferred superhero (own all dvd film, and what is published in italy about Kal El)) is absolute right!.
    and , as usually take your time for learn and discover, Linux is a fascinating world
    best wish
    BHH
  11. Man of Steel freebird73717's Avatar
    Buzz you shouldn't apologize. Honestly your written english is better than most that speak it natively!
    buzzqw, you certainly have nothing to apologize for to me. You have been very helpful. I did not know english was not your native language.
    I did the manual cedocida method. It seemed to work. Then I started my hcenc and I got the fourcc mjpeg error again. I think it means it cannot find a codec. It is there, so how do I make hcenc use it? I had to delete the picvideo dll because it used it again. I was hoping after deleting that it would use the cedocida codec but it has not noticed it.
    Thanks to you both for your great help. And yes, I do love linux, too.
    Sincerely,
    Marcia
  13. cedocida is an Coder and Decoder (aka CoDec) for dv files, encoded with DV codec
    BUT if your video is encoded in mjpeg.. cedocida cannot decode it, you need a mjpeg decoder!
    OR you can decode your mjpeg files with ffmpeg in lossless format (huffyuv or lossy DV ) then feed hcenc
    ffmpeg -i file.avi -an -vcodec dvvideo file_dv.avi
    BHH
  14. Man of Steel freebird73717's Avatar
    One other thing you could try is the dv decoder in ffdshow. Install through wine like normal then change the DV and Other DV settings from disabled to libavcodec in the ffdshow video decoder tab.
  15. Member GMaq's Avatar
    Hi,
    ffdshow will run under WINE? That's great to know, thanks for sharing that Freebird.
  16. Man of Steel freebird73717's Avatar
    Originally Posted by GMaq
    Hi,
    Yep. I use it primarily for decoding h264.
    Thank you so much for the info and wonderful info about ffdshow, too. Now, I understand a pinch more about all of this. Thanks to your info about the codec I finally was able to use hcenc correctly. After I used mplex to combine the video and sound it was not dvd compatible yet. So, I took my video into avidemux, another great tool IMHO, and made it dvd compliant without reencoding. That worked. I was able to put it into KDE DVDauthorwizard and make an iso to burn with K3b. The results were excellent especially considering this was one of the worst videos I shot - too much movement, not the right lens used for the poor lighting, etc.
    For comparison I did one with devede. It was actually very good, too, but I need to learn mencoder tweaking more to get rid of the noise. The problem with devede it would not give me the 4:3 aspect that I wanted. It gave me 16:9 even though I checked 4:3. I do not know why. I think it may be possible to get devede to put out the quality of hcenc if I tweaked mencoder just right. That is somewhat my goal since devede is so easy and linux native.
    I have to admit I am impressed with hcenc and the hcbatchgui made it easy to get the avs file just right.
    Thanks for this great education and tools.
    Sincerely,
    Marcia
  1. Problem with HCenc 0.24.
    By HolyFries in forum Video Conversion
    Last Post: 17th Jun 2010, 18:03
  2. Problem with HCenc 0.24.
    By HolyFries in forum Newbie / General discussions
    Last Post: 17th Jun 2010, 13:18
  3. HCenc Question
    By Maikeru-sama in forum Video Conversion
    Last Post: 18th Aug 2008, 12:01
  4. HCEnc vs MVBR
    By awesomer in forum Video Conversion
    Last Post: 31st Jul 2008, 18:12
  5. HCEnc
    By Belfour in forum DVD Ripping
    Last Post: 28th Jun 2007, 09:57
