VideoHelp.com Forum
    First let me apologize if this has been covered as my search did not reveal an answer.
    I am set to convert many 8mm tapes from my old analog Hitachi camcorder by passthrough into and out of a Sony HC96 DV camcorder and then by firewire into my pc.
    My question is the type of cable between the camcorders for the best picture and sound. One option that does work is to use a cable that connects from the analog Hitachi by RCA jacks and into The Sony HC96 a/v input.
    The analog Hitachi also has an output that I'm not sure what it is called. It's rectangular 1/4"x5/16", has 20 pins but only 7 are used. The other end of this cable has RCA jacks plus S-video but these will not connect into the Sony. Should I try and find a cable with the rectangular output on one end and a/v input on the other? Possibly find a cable that accepts the S-video and RCA sound jack and would connect to the Sony a/v input?
    Thanks for any replies,
    Brad
  2. Member Krispy Kritter's Avatar
    Bottom line, use what works. Depending on the source, there likely isn't much difference anyway.
    Google is your Friend
  1. Camcorder with analog to digital passthrough feature
    By chuckaug in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 14th Jan 2011, 17:49
  2. Urgent Question Sony CCD-TRV438E Hi-8 Analog Camcorder
    By Shaga in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 20th Oct 2008, 13:32
  3. Vista Digital Camcorder capture question
    By Hal05154 in forum Capturing
    Last Post: 17th Dec 2007, 03:06
  4. Replies: 4
    Last Post: 30th Jul 2007, 23:32
  5. What is the Best MiniDV Camcorder with analog/digital pass-through
    By DigitalGuard in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 20th Jun 2007, 14:18
