Now, this is a bizarre error.
My DMR-EZ27 was recording just fine on DVD+R media (16x speed) up until yesterday when I got an "Err" then a U61 error, and the usual shutdown routine that does absolutely squat.
I was also getting READ-ONLY errors on DVD-RAM when I tried to record on it, or delete a recording, or formatting!
Basically, it would not record on anything, but it played commercial DVD's just fine.
I suspect that this model is VERY sensitive to vibrations because the problems developed after I was trying to tighten the shelf it was sitting on.
I did a HARD RESET several times, and now it is able to record on DVD-RAM and DVD+RW, but I'm still getting U61 errors with DVD+R -- with which it previously had no problems.
This unit is supposed to be able to write on dual-layer media, so I don't think it is because I'm using a 16x DVD+R. Remember, it recorded on them just fine yesterday.
I wonder, though, if it likes DVD-R more becuase that WAS the native format of previous Pannys.
Tomorrow, I'll try throwing a 4x DVD-R at it and see if I still get the U61 error.
I suspect that I will.
BTW, my RCA-8000N records the 16x DVD+R's just fine (and +R's & +RW's are the sole format on which it can record).
Seeing as how I can record on rewriteable, but not on read-only disks, I would not think that a power-leak is the problem.
Structurally, what's the difference between a +R and a +RW?
Any ideas?
UPDATE
I'm now able to record on a TDK DVD-R now.
Tonight, I'll try a TDK DVD+R
If that works, well, then I guess it went back to the way it was before the errors.
Well, it still will not write on DVD+R.
So, I guess I stick to DVD-R's.
Multi-drive? NOT.
Panasonic DMR-EZ27 Chip set?
By Deter in forum DVD & Blu-ray RecordersReplies: 5Last Post: 17th Sep 2008, 18:26 -
Panasonic LSI for DMR-EZ17,EZ27...?
By cosmin in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Aug 2007, 22:17 -
DVD Recorders that records to + media?
By SteveMKIIDub in forum DVD & Blu-ray RecordersReplies: 5Last Post: 21st May 2007, 12:54 -
Streaming media recorder that records directly to MPEG 1/2?
By Moritain in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2005, 17:52 -
Panasonic E-50 only records to 1x media?
By sadbugger in forum DVD & Blu-ray RecordersReplies: 14Last Post: 11th May 2004, 20:38
Statistics
Newest guides
Latest tool updates
New media comments
