How often did you had to turn up the volume of your television set / DVD player to hear the audio of your DVD discs, which were created with AC3 files?
This application addresses some of the volume issues with transcoded AC3 files. It is based on a Soopa toolkit, just in a GUI format. Soopa created some batch files, which use AviSynth, Aften and WAVI. The original batch files and article can be found here: http://forum.videohelp.com/topic317891.html
He gave me permission to use the batch files as a basis for this application, and this is the end product.
It is very easy to use. You can either process a group of AC3 files in a specified folder, or drag and drop AC3 files into the application folder for processing. You can select your own bitrate and level of dynamic range compression. If you have VideoLAN installed, then you can play the AC3 files in this application.
Requirements: AviSynth 2.57 or higher
For more screenshots and downloads, please visit this page:
http://doctorjellybean.googlepages.com/ac3normalizer
Results 1 to 10 of 10
Thread: AC3 Normalizer GUI
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
at start of script I see
"could not find C:\tmp\*.avs"
Also when using 2.0 ac3 files you loose the right channel upon conversion.
Also, perhaps you should add in a clean up as afen, dlls, etc are left in source folder
nice app'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
It has been removed altogether, info regarding this has been added to Help tab. Updated app files have been uploaded.Originally Posted by ron spencer
This is to delete any exisiting avs files prior to processing for the first time. No harm done if it doesn't exist.at start of script I see
Have to investigate this further.Also when using 2.0 ac3 files you loose the right channel upon conversion.
When the app exits, it should automatically remove all the files. Please confirm that it doesn't happen.Also, perhaps you should add in a clean up as afen, dlls, etc are left in source folder
Glad you like it
ok....I did some checking.
I can verify that the dlls and afen, etc. are deleted....but only when you exit your program (I had left it open...sorry)
Now as far as 2.0 AC3 is concered, this program will convert to 5.1....perhaps only 5.1 files can be used?
see:
says only 5.1
if only 5.1 perhaps you should put this in help so people don't get confused (like me LOL).
If you can somehow make it do 2.0, that would be useful too
thanks again!!!!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
some users may have some .avs files in their working folder...so perhaps a warning in the help section that they will be deleted may be useful as well.
cool proggy!!!!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
Support added for 2.0 files! Updated files uploaded.
Today I downloaded the AC3 Normalizer to level up the volume on an AC3 file I have.
But I'm having some problem on the setup, because apparently my file is 448Kbps, and the program accepts Bitrates only up to 384Kbps.
Also I don't know what Dynamic Range Compression to apply, as I don't know what ratio my file is.
Where can I get such info?
This tool needs to support higher bitrates including 640kbps.
Hi,
Looks good! Easy to use.
Why does it say it needs .NET 1.1 ot later? It runs without any .NET version installed.
I'm running it in W2K SP4 and it crashed on Aften.
I downloaded Aften from here and copied it to the workfolder. Then I made it readonly
so your app couldn't overwrite it and from then your app did fine.
The Aften included in your app is dated 12-03-2008
The downloaded version from here is dated 28-12-2008
Would be nice if you could replace it.
Thanks,
Chris
GUI for dvdauthor AC3 error
By rancid in forum Authoring (DVD)Replies: 6Last Post: 4th Jan 2008, 00:25 -
New Simple GUI Version of Aften AC3 Encoder
By Soopafresh in forum AudioReplies: 3Last Post: 6th Feb 2007, 20:23 -
Levelator v1.1.0 - Dialogue Normalizer for WAVs
By Soopafresh in forum AudioReplies: 0Last Post: 3rd Feb 2007, 19:10 -
Looking for a real-time sound normalizer
By Quimbly in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2006, 10:18 -
Adding ac3 with gui for dvdauthor
By Dilemma in forum Authoring (DVD)Replies: 2Last Post: 14th Apr 2005, 05:54
Newest guidesLatest tool updatesNew media commentsDVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
