VideoHelp.com Forum
Results 1 to 10 of 10
    Hi, I thought I'd do the desent thing and help a friend convert a DVD (The file TRON) to his iPhone, other than spending money on software to do this, is there a free way of doing this?
    Many thanks
    You legend Balrick (Blackadder was the best)
    I meant Videora Iphone Converter...not Ipod.
    Many thanks again for you useful quick reply! let me try this now and get back to you.
    Can this too be used for my Sony PSP too?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    I guess both support mp4 with h264 so I think it will work. Or else can you use PSP Video 9. Or check our tools portable list for several free tools, http://www.videohelp.com/tools/secti...obile-psp-ipod . All may not support ripping from the dvd directly but you can then use dvdfab decrypter to rip the dvd your hdd and then make a mpg from the dvd using vob2mpg. OPen the mpg in the converter.
    I am just trying Videora Iphone Converter and it asks me to select the file, seems my DVD has about 6 VOB files, do I select all of these?
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Make one file from the dvd using dvddecrypter, http://www.videora.com/en-us/Convert...e/dvd-to-ipod/
    Or use vobmerge to join all vobs. (You must have ripped the dvd to your hdd first)
    Thanks all done. I used dvddecrypter which did the vob files, then used the Videora Iphone Converter. My only problem is my movie is 597MB, is this a normal size for an mp4a?
  1. Convert .avi to iPhone .mp4
    By kabuto in forum Video Conversion
    Last Post: 14th Mar 2011, 03:51
  2. Convert iPhone 3GS Video to AVI
    By Juergen12345 in forum Newbie / General discussions
    Last Post: 25th Aug 2009, 16:10
  3. Replies: 3
    Last Post: 16th Aug 2008, 13:25
  4. Steps and Tips: How to Convert DVD to iPhone on Mac
    By guns1inger in forum User guides
    Last Post: 23rd Aug 2007, 22:46
