Results 1 to 11 of 11
    i know this is a stupid question but i've got a philips 3590h and can't seem to work out how to record straight to disc. i can record to the hard drive but not to disc i've looked in the instructions but can't find anything. if anyone could help me it would be much appreciated
    thanx
    There should be a button to select the DVD drive before you record to it. Might be one of the top ones, if remote is same or similar to 3575H. If like 3575, whatever drive you leave machine on is what it'll start up on next time, so if you don't see a timer rec going, make sure you're looking at HDD activity by pressing HDD button.
    I just looked at your manual, it's on page 45, press HDD/LIST, cursor to the title you want and press the green button on your remote.
    ok guys i managed to copy to disc but i can't seem to finalize the disc and how would i be able to record from sky+
    thanx
    Finalize should be in the Disc Edit menu.
    thanxfor that. still any idea how to record straight to disc without going through the hard drive first
    thanx
    thanx
    Did you find a DVD button that makes that drive "active" instead of the HDD?
    I just looked in a EU 3595 manual and it looks as if you can only rec directly to DVD: (1) when setting a timer rec program, it'll be last option for "Recording Target", and (2) if using an external device, like a VCR... you press the CAM button, which gives you a choice between HDD, Optical Disc and Cancel (after a warning about clearing the time shift buffer).
    no i can't find the dvd button
    See my post above your last one.
    ok thanx for the help
  1. Philips DVDR3590h and no signal detected
    By m_fardan in forum DVD & Blu-ray Recorders
    Last Post: 20th Feb 2009, 14:07
  2. Philips 3506 can't play recording
    By Policy Peddler in forum DVD & Blu-ray Recorders
    Last Post: 24th Jan 2009, 20:38
  3. Philips dvdr3590H, hardware clicks and almost ruins cd/dvds.
    By aleks93 in forum DVD & Blu-ray Recorders
    Last Post: 21st Oct 2008, 01:16
  4. Philips 3355 off center recording
    By stagescrew in forum DVD & Blu-ray Recorders
    Last Post: 23rd Jan 2006, 15:48
  5. Philips DVDR70 - Recording from a Video possible?
    By eng2ajd in forum DVD & Blu-ray Recorders
    Last Post: 4th Feb 2004, 09:37
About   Advertise   Forum   RSS Feeds   Statistics   Tools
