VideoHelp.com Forum
Results 1 to 10 of 10
    Hi all,
    Ive got a Technika DVD recorder that allows one of the Divx or Xvid formats to be played. I was looking for a way to plug in my External HDD and play my video clips of that without having to burn them all to DVDs....
    Anyone know any players that fit this bill? or is USBDirect jsut image and audio?
    Thanks.
    I'm not sure what you mean by "USBDirect", but there are several players that allow you to play Divx/Xvid via devices attached by USB. Philips makes several. But there is a catch - your device (flash drive, hard drive - whatever) MUST be formatted as FAT32. NTFS is NOT supported at all. You can thank Microsoft for this by charging too much for NTFS drivers.
    grrr thats annoying
    I saw the philips ones but so far ive only seen that they support images and videos. If they run video files thats annoying as I converted my HDD from FAT32 to NTFS!
    I just wanted to make sure that they "could" play video files and not waste my money
    I believe the new Panny EZ-x8 series recorders will play divx and such through its USB port. At least I believe the little card on top of the unit said that. I personally never tried it.
    FAT32 has theoretical limit 2TB. In Windows XP/2000 are commands fdisk and format limited to use maximum size of 32GB with FAT32. It is limited by Microsoft! Try to search internet to find fdisk and format from older Windows versions or other similar tools, e.g. here http://www.ridgecrop.demon.co.uk/ind...at32format.htm
    Remember, you can format for example 400GB drive with FAT32, you need only right tools!!!
    Try search: FAT32 format limit windows
    Pioneer DVR-530H-S fw3.56 400GB HDD
    discoverer of 2nd hidden menu
  6. You could get this for $99
    www.klegg.com
    They are now selling it right from their web page for $99.
  7. The SumVision Phoenix DVD player has a USB socket. As mentioned above, the drive must be FAT32. Also it seems to scan all the files on the entire drive before showing a list. So you don't want to plug in a drive that has loads of stuff on it (eg. Windows). Just one with all your movies. I have the Phoenix and have yet to find a DivX or XVid file that it won't play.
  8. Philips recorders can do divx on HD on USB this there is a really big topic on it.
    My Xbox 360 can play divx through the network connection to the computer.
  9. Member yumagah's Avatar
    Target stores sell a DVD recorder with the "Trutech" brand that has a USB in port and plays DIVX/Xvid. I have one that I got cheap - it was a display model. The USB port on mine does not supply power - I assume this is a defect - so I can only connect USB cameras & hard drives that provide their own power. But it plays Divx ok from the drives or memory cards.
    This unit has lots of bad reviews online about QC problems.
  10. Just bought a Philips 5990 at outlet for $25 free shipping, refurb. Usb 2.0
  1. hdr-cx115e live view: direct connection to tv or mac --> tv??
    By paolocardelli in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 2nd Oct 2011, 17:27
  2. dvix/xvid to dvd using ffmpegx???
    By Jgarlich in forum ffmpegX general discussion
    Last Post: 20th Jul 2009, 20:57
  3. Replies: 9
    Last Post: 11th Mar 2009, 22:50
  4. dvd player +dvix+usb with external 160GB external HD problem...
    By spidermen in forum Newbie / General discussions
    Last Post: 14th Oct 2008, 19:45
  5. Connection between PC and DVD recorder
    By mish159 in forum DVD & Blu-ray Recorders
    Last Post: 3rd Jun 2008, 19:29
