Hi All,
How to connect VGA port on laptop to Svideo port on tv, what is the cable we need to use ???
Iam able to connect it to another monitor via VGA out.
Thanks,
Unless your laptop is one of the few that supplies s-video on the VGA port's unused pins, you don't. You will need a scan converter:
http://www.google.com/search?hl=en&q...=Google+Search
Note that s-video is much lower resolution than your typical laptop's LCD so it will be very fuzzy.
A similar thread:
http://forum.videohelp.com/topic351615.html
You don't have a laptop "TV port" ?Originally Posted by hulk420
What model laptop?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I recommend this converter:
http://www.tigerdirect.com/applicati...gtCjCVRqCjCVRq
A friend has one and he likes it.For best picture set the output on your laptop to 640x480/60Hz/16bit.
There is a mini-trend for budget laptop manufacturers to offer "TV out" (S-Video, composite, YCbCr) only on the port extender option*. This would offer marginal higher quality solution vs. an external standards converter.
* Idea is low end buyers are only interested in price on initial purchase so the manufacturer puts important connectors on the high margin port extender option. Similar to an auto manufacturer making the trunk (aka boot) key a $500 option.Recommends: Kiva.org - Loans that change lives.
Problems connecting a laptop through the SVideo port to a Display VGA input
By jeproca in forum Newbie / General discussionsReplies: 21Last Post: 4th Nov 2010, 09:31 -
Video panel lost on 2nd monitor on laptop VGA port
By jeth32 in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2010, 20:08 -
Howto connect VGA to S-Video port?
By bulava in forum DVD & Blu-ray PlayersReplies: 3Last Post: 8th Jan 2010, 09:12 -
laptop vga port wont work on my moniter
By kingnat2 in forum ComputerReplies: 2Last Post: 12th Jul 2008, 17:47 -
Will this cable work to connect my Epson S3 VGA port to aHDMI DVD recorder?
By NG in forum Newbie / General discussionsReplies: 2Last Post: 13th Dec 2007, 23:20
