Hello all,
I have been using the SONY DVD Writer. Recently almost everytime when I write some data into DVD disc & take out the DVD disc after writing completed & put it again in to the DVD writer, my PC identifies the DVD media as CD media & it shows that it is blank as if no data is inside.
Does any one face the similar kind of issue. Is it a problem with DVD writer or the DVD media. I even tried writing the DVD at low speed from 8x, 12x, 16x. All of the returns the same result.
Request your valuable help in this..
Thanks in advance.,
Anand.
Have you tried different media? Crappy media can cause such problems but if it happens with all media it's could be a dvd writer problem.
It would be helpful if you posted what brand/model of your dvd burner. Also post the media id of the dvd media that you're using as well as what software you're using to burn the dvd media.
Both false, I think.Originally Posted by its_me
Uninstall the ide drivers, then restart.
Thanks for the replies...
I am using Sony DVD writer & Nero 7 software. The problem comes sometimes when I use sony DVD media or Moser baer or any unbranded media..
Hello chef,
i would like to try your idea of uninstalling the IDE drivers.. Could you help me .. How to identify the IDE driver to which the DVD writer is connected..
Thanks in advance.,
Anand
Use IMGBURN to burn dvd media as NERO is crappy to use. Also MOSER dvd media is considered low grade dvd media which is probably why you are not able to read those them after it's burned.Originally Posted by its_me
DMA 5 is for hard drives and dvd burners are usually DMA 2 or 4.
Use this guide on uninstalling the ide drivers:
http://www.cdrlabs.com/forums/proble...ows-t6645.html
finalizing dvd after image has been written
By Down1oader in forum Authoring (DVD)Replies: 3Last Post: 1st Dec 2011, 17:10 -
Written/burned DVD-R Question
By BrokenOne in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Apr 2008, 23:11 -
Sony written DVD not copying on PC
By Sainkho in forum DVD RippingReplies: 4Last Post: 12th Apr 2008, 22:21 -
Where is written data of vertical position of DVD subtitles
By dinderi in forum Authoring (DVD)Replies: 25Last Post: 27th Mar 2008, 10:01 -
Sony DW-Q28A can't read DVD+R written on itself
By mackayr in forum DVD & Blu-ray WritersReplies: 3Last Post: 5th May 2007, 18:31
