Ok I got a dell d610 latitude laptop with 2 Ghz pentium processor, windows xp pro OS, 60 GB HD, and a ATI Radeon X300 graphics card. On occasions when I watch my video files they tend to freeze up then lag...is it possible that its due to the graphics card or is it something else? is it possible to change the graphics card into a better one if this is the case?
Not likely to be the card itself. Driver or player software is a possibility.
Another thing to look at is CPU usage and how much memory you have. If the laptop is swapping to the hard drive all the time that could cause what you describe. Another problem could be the DVD drive. Many things to check.
It usually isn't a card in a laptop. Dell has made a few models that use a special video card instead of being built-in. You would have to call Dell about that and be sure to have the service tag number off of the bottom when you do. That should let them look up your specific build info.
its video files on my laptop, however it may be the cpu usage considering how i use a heavy antivirus program. and running other programs inthe background too. i use real alternative 1.8 to run my videos...is that bad?
You can check the cpu usage yourself to see if that is the problem (most likely). The only solution, is to shutdown or disable other apps that are running. If you insist on keeping all of the apps running, then you either have to live with the stuttering video or get a laptop with a faster cpu to handle the work load.
Google is your Friend
burner causing problem with wireless internet
By zerocoool in forum DVD & Blu-ray RecordersReplies: 6Last Post: 6th Jan 2010, 01:19 -
Video Card for LIVE Tv Watching (zero second delay)
By mabus in forum Media Center PC / MediaCentersReplies: 38Last Post: 1st Dec 2009, 12:00 -
problem in megui causing SHUTTING DOWN my computer !
By LOST World in forum DVD RippingReplies: 5Last Post: 15th Feb 2008, 04:45 -
Vdub audio filters causing problem on video track
By SearchQuality in forum AudioReplies: 4Last Post: 10th Feb 2008, 11:42 -
Video Card TV-Out problem...
By ToastMan85 in forum Media Center PC / MediaCentersReplies: 0Last Post: 16th Dec 2007, 12:13
Statistics
Newest guides
Latest tool updates
New media comments
