I couldn't find an answer to this in the forum already, so I hope someone knows the answer.
I'm using ffmpegx to encode a .mov exported from final cut pro through compressor (using quicktime preset) into a .flv. From the default settings, I changed the framerate to 29.97, but I think I left all of the other settings at default.
My video gets progressively further and further out of sync, until my video is so far behind the audio that I can't tell anymore where it's supposed to be. It's about a 30 minute video, but it's cut to 16:20.
I'll eventually post a log and try to tweak it and test, but if anyone knows what I'm doing wrong already, I'd be obliged if you could point me in the right direction. Thanks!
-Chris
Okay... trying different settings in compressor seemed to fix the problem. By encoding it through h.264 or mpeg4 instead of compressor's default quicktime setting, the flash movie played perfectly in sync. That sync issue happened regardless of the 29.97 frame rate or the 15 fps rate. The issue, then, seems to have something to do with that basic quicktime setting.
No big deal now - I'm cool with using h.264 myself if there are no known compatibility issues.
.mov to flv conversion completely out of sync
By lilly333 in forum MacReplies: 1Last Post: 23rd Jan 2010, 04:34 -
Issue converting a .mov to a .flv
By bopdro in forum ffmpegX general discussionReplies: 1Last Post: 5th Mar 2009, 13:15 -
FLV file with severe lip sync issue
By neftv in forum Video ConversionReplies: 4Last Post: 3rd Mar 2009, 16:26 -
.mov conversion to .flv - issue with caption
By jp_drums_4evr in forum Video ConversionReplies: 0Last Post: 29th Jun 2008, 15:40 -
mov to flv choppy video
By johntay555 in forum ffmpegX general discussionReplies: 3Last Post: 8th Jan 2008, 13:30
Statistics
Newest guides
Latest tool updates
New media comments
