Thread: video size VCD
    I have trouble when export the photo to MPEG-1 using Magix movie edit.
    The result of MPEG-1 has bad resolution of image than original one.
    I'm trying use video size 720x480, 720x576 and 768x576 with 4000 Kbits/sec (bit rate), 29.97 (frame rate)
  2. Banned
    Hi there.
    Does that mean you want an MPG still-frame
    If so, then you'd better be using TMPGEnc and an adequate quantize matrix:
    08 08 08 08 08 08 08 08        08 08 08 08 08 08 08 08
    HTH.
  3. Member AlanHK's Avatar
    Well, the VCD spec is:
    http://www.videohelp.com/vcd
    PAL Video: (Shouldn't you use that in Singapore?)
    1150 kbit/sec MPEG-1
    352 x 288 pixels
    25 frames/second
    or NTSC/NTSC Film
    Video: 1150 kbit/sec MPEG-1
    352 x 240 pixels
    29,97 frames/second
    23,976 frames/second NTSC Film
    So you see it's much lower resolution and bitrate.
  4. Member Cornucopia's Avatar
    Are you trying to make a VCD with
    1. a series of user-advanceable MPEG stills?
    or
    2. a video track pre-mixed-down from a timed/transitioning slideshow?
    #1 allows encoding MPEG1 stills format (704 x 480/576), wheras #2 only allows MPEG1 video format (352 x 240/288). Use VCDEasy's stills encoder tool for the stills, use TMPGEnc for the video.
    Also, if you're actually trying to make a compliant VCD, your bitrate is WAY too high!
  1. video Size for VCD and DVD
    By newbievideohelp in forum Newbie / General discussions
    Last Post: 20th Nov 2009, 03:28
  2. VCD video size????
    By DMXiNc in forum Newbie / General discussions
    Last Post: 29th Jul 2003, 10:31
  3. Size of Video (Not Bytes size resolution size eg 352x240)
    By Andy149 in forum Video Conversion
    Last Post: 15th May 2003, 04:41
  4. Video Size on VCD too Big for TV
    By Ranthali0n in forum Authoring (VCD/SVCD)
    Last Post: 23rd May 2002, 12:01
  5. What size Video file will fit on a VCD
    By BMzx in forum Authoring (VCD/SVCD)
    Last Post: 12th Jan 2002, 19:51
About   Advertise   Forum   RSS Feeds   Statistics   Tools
