Results 1 to 15 of 15
  1. Member deejay.2001's Avatar
    Dec 2002
    hi
    i have dvd with those files below where VTS_01_0.IFO IS MISSING
    nero will not allow to burn
    can i generate this ifo with ifoedit somehow?
    please let me know how if you know..thanks
    VIDEO_TS.BUP
    VIDEO_TS.IFO
    VTS_01_0.BUP
    VTS_01_0.IFO
    VTS_01_0.VOB
    VTS_01_1.VOB
    VTS_02_0.BUP
    VTS_02_0.IFO
    VTS_02_0.VOB
    VTS_02_1.VOB
    VTS_02_2.VOB
    VTS_02_3.VOB
    VTS_02_4.VOB
  2. Banned
    Freedonia
    Open a command prompt in whatever version of Windows you have (Run followed by
    cmd
    will do the trick) and give this command exactly:
    copy VTS_01_0.BUP VTS_01_0.IFO
    BUP files are backup copies of IFO files with the same name, so all you have to do is copy the BUP to the IFO name and you are good to go. That's what BUPs exist - you've got a backup in case you need it.
  3. Member Seeker47's Avatar
    Jul 2005
    Originally Posted by deejay.2001
    hi
    VIDEO_TS.BUP
    VIDEO_TS.IFO
    VTS_01_0.BUP
    VTS_01_0.IFO
    VTS_01_0.VOB
    VTS_01_1.VOB
    VTS_02_0.BUP
    VTS_02_0.IFO
    VTS_02_0.VOB
    VTS_02_1.VOB
    VTS_02_2.VOB
    VTS_02_3.VOB
    VTS_02_4.VOB
    My knowledge of this stuff is extremely limited, so it's a good bet you can find better advice. But I'm pretty sure I have managed to generate the other files when I had nothing but the .VOBs -- and it wasn't using a program that's as complicated (to me) as IFOEDIT. I'm thinking it must have been FixVTS. All I can tell you is that I've done this a few times, and if I could do it, it can't have been that difficult.
    When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- over 150 tables from 6+ decades of this gradually disappearing American art form.
    Aug 2005
    Palo Alto, California USA
    Try jman98's suggestion first. As he correctly states, ".bup" is the extension for ifo "backup" and it exists for exactly these scenarios.
    If the bup file is also corrupted, then you will have extra work to do, to regenerate a fresh ifo from the vob's themselves as seeker47 described.
  5. Member deejay.2001's Avatar
    Dec 2002
    cmd
    thanks but that command is not clear for me...
    can i just copy bup file and rename it to ifo (in total commander)and add it to movie? is that what you mean?
    thanks
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Yes - or windows explorer. Whatever you are comfortable with
    Read my blog here.
    Apr 2007
    Australia
    Hi deejay.2001
    All answers are correct.
    This one is as easy as 1, 2, 3.
    AND it uses Ifoedit.
  8. Member deejay.2001's Avatar
    Dec 2002
    thanks guys
    ifo is ok now but another problem came up when i tried to burn...
    VIDEO_TS.VOB is missing also ....nero says now
    what i can do with it now?
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Where did this come from ?
    Read my blog here.
  10. Member deejay.2001's Avatar
    Dec 2002
    i do not know where it came from...nero says that when i tried to burn
    ifo problem fixed...and now this thing,,,,
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    So you didn't create the files ?
    Try removing the video_ts.ifo and bup files, then recreate the ifos with IFO edit, then burn.
    Read my blog here.
  12. Or just use ImgBurn. You don't need the VIDEO_TS.VOB.
  13. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Players will have problems if there is a video_TS.ifo
    Read my blog here.
  14. If there is a VIDEO_TS.IFO but no VIDEO_TS.VOB to go along with it? Not in my experience. PGCEdit even asks to remove the VIDEO_TS.VOB if there's no content. I always say yes and have no problems at all. It is not required. The Nero complaint is a well-known and pointless quirk. ImgBurn, which everyone agrees is the best burning app by far, doesn't care and will happily burn a VIDEO_TS.IFO and VIDEO_TS.BUP with no VIDEO_TS.VOB.
    Mar 2008
    Near the Beach
    Run FixVTS once again. It removes the false VIDEO_TS.VOB entry.
    Then try Nero once again. If Nero doesn´t report an error, you can burn this with Nero or ImgBurn.
