I don't know if this is possible, but my computer has issues with mkv quite a bit. It keeps freezing. So i would like to convert it to avi with hard sub. Is that possible? I have tried using mkv extract to extract the audio and video along with the subtitles. Then i used mkvmerge to put the audio and video back together. Then i would use SUPER to convert the the joined media into avi. This often fails for some reason. I made sure that the frame rate is correct but stil it comes at as only ten minutes long. But let's take the example that it works. i then tried to use avi recomp to add the subtitles. it keeps failing to do it. the error message pops up to fast so i can't tell you what the error is. T^T. I managed to do this before and it worked. but nowadays i fail everytime. Help please.
Did it work with same mkvs before? Because mkv could contain different video and audio and if it's variable frame rate it's even worse.
And have you tried play the mkv with media player classic and use haali media splitter and coreavc for h264/decoding? It may help a lot for slower computers.
MKV with softsubs to AVI hardsub
By Rick-E in forum Video ConversionReplies: 1Last Post: 28th Mar 2011, 15:27 -
MKV to hardsub AVI with fonts
By panguboy in forum SubtitleReplies: 4Last Post: 18th Jan 2011, 10:29 -
How to make softsub from hardsub subtitle
By lequios in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2010, 00:50 -
Making Softsub into Hardsub
By iKhoa in forum SubtitleReplies: 0Last Post: 2nd Jul 2010, 13:58 -
Help extracting softsub from a .mkv movie file.
By Danilux in forum Newbie / General discussionsReplies: 2Last Post: 13th Oct 2008, 23:18
