I get an error trying to add a sub to an existing mkv file:
Warning: 'C:\Documents and Settings\User\Desktop\German.srt': This file contains coordinates in the timecode lines. Such coordinates are not supported by the Matroska SRT subtitle format. mkvmerge will remove them automatically.
I have used a subtitle that was made in SRT2SUP. I tried a sub saved as a txt and renamed SRT, and when I added the file, MKV merge thought it was a video track!! What do I got to do to make it work?
What I did was take an existing english sub and extract it, then translate it, and am trying to put it back with a different filename.
Thread: MKV Merge subtitle error
Why not just use the SRT subs you translated, if that is what you want ? You can take an SRT, convert it to SUP format, then just rename it to SRT
MKV with MKV Merge Unicode not compatible with LG BluRay Player
By klode in forum Video ConversionReplies: 3Last Post: 8th May 2011, 03:42 -
How to move subtitle position vertically and merge to mkv
By riojisan in forum SubtitleReplies: 1Last Post: 4th May 2010, 18:07 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
mkv merge
By runLoganrun in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2008, 06:53 -
Help how i can Merge subtitle with movie?
By WhitGer in forum SubtitleReplies: 0Last Post: 25th Mar 2008, 01:16
Statistics
Newest guides
Latest tool updates
New media comments
