VideoHelp.com Forum
  1. i just downloaded vcdeasy and when i chose how often i want my chapters it doesn't accept it, i try burn every.. and that doesn't work, i try make a chapter at... and that doesn't work either, what am i doing wrong?
  2. It depends basicly on two things, if you encoded your MPG with GOP closed it should work, and you must also allow VCDEasy to scan your MPG for the entry points for the chapters to work.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. Sorry if I'm starting a new topic, but what is GOP (high level)?
    I can't find an explanation on this site?
    (and search is offline)
  1. Administrator Privilege to Run VCDEasy
    By asifmcp in forum VCDEasy General
    Last Post: 8th Jan 2011, 04:48
  2. VCDEasy doesn't work in Vista...
    By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)
    Last Post: 26th Dec 2010, 20:20
  3. Burning with VcdEasy
    By gkma01 in forum Authoring (VCD/SVCD)
    Last Post: 19th Sep 2008, 20:00
  4. Problem with creaing Menu in VCDEasy
    By haris in forum Authoring (VCD/SVCD)
    Last Post: 16th Mar 2008, 08:17
  5. How will I make an AVCD using VCDEasy?
    By zeldAIS in forum VCDEasy General
    Last Post: 4th Aug 2007, 15:13
