VideoHelp.com Forum
    Hi,
    Do you think that H.264 is a better option then DivX?
    I know that, using the same bitrate, H.264 has a little bit more quality than DivX.
    However, DivX seems more widely used and compatible than H.264.
    Which format would you use?
    Thanks,
    Miguel
  2. Member yoda313's Avatar
    I think you might have answered your own question there. Divx has been around longer than h264 I believe and has more native support. It would be the better choice if you are unsure of your destination.
    With that said if you know what your destination is and can support both codecs than I would say do a test run. Take a video clip and convert it to both formats. Then play it on whatever device you plan on using. Whichever one looks better to you would be the winner. Since this somewhat subjective that is about the best you can do.
  1. DivX vs. H.264. vs. Divx HD: What best for playback on Philips BDP5320 ???
    By Lord Stinkfoot in forum DVD & Blu-ray Players
    Last Post: 21st Sep 2011, 04:50
  2. h.264 to divx
    By degarb in forum Video Conversion
    Last Post: 4th May 2010, 11:27
  3. H.264 - Divx..... problem !!!
    By tjolle62 in forum Portable Video
    Last Post: 25th Mar 2009, 16:45
  4. .264->DivX
    By waefwaeefwaefw in forum Video Conversion
    Last Post: 3rd Jan 2009, 15:33
  5. dv-avi to divx/x.264
    By simoupnorth in forum Video Conversion
    Last Post: 23rd Jan 2008, 17:04
