VideoHelp.com Forum
Thread: Canon HV20/HV30
  1. My sony trv19 has stopped working correctly. The video flickers and becomes very pale looking. I tried cleaning it but it didn't help.
    So I'm looking to buy a new camcorder and I'm thinking of getting the canon hv20 or hv30.
    Which battery provides the most recording time? BP-2L14, BP-2L24H, BP-2L13, or NB-2LH?
    Since the viewfinder doesn't extend, does a large battery and the DM-50 microphone make the viewfinder unusable?
    Does a minidv tape hold the same amount of hdv video as it does dv? How?
    What wide angle lens should I get? I had .45x wide angle on my trv19 and it was a
    litte too wide at times.
    I also need to know if the hv20 with a wide angle lens and a larger battery will fit in my old sony handycam case, including the detached microphone.
    i'd suggest going to a video store and trying it out. actually putting your hands on the cam and shooting some footage with it will give you an indication of whether or not you will like it. take your old bag with you.
  3. BuskerAlley.com zoobie's Avatar
    http://www.camcorderinfo.com/content...view-34401.htm
    http://www.camcorderinfo.com/content...der-Review.htm
    I usually recommend going the semi-pro route and at least getting a cam with LANC to use with your remote controller on your tripod...but it adds around $500 and 50 lbs...but the shots are great
    convenience is evidently king...
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
  4. Member Soopafresh's Avatar
    Check out the HV20 FAQ at http://www.hv20.com
  1. Cannot capture HDV with Canon HV30
    By ChrisU in forum Capturing
    Last Post: 4th Mar 2012, 21:56
  2. Canon Rebel xti + Canon HV30 vs. Canon Rebel T2i
    By assman24 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 17th Jun 2010, 11:47
  3. canon hv30 to cimputer
    By gilgeva1 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 29th Apr 2009, 11:54
  4. canon hv40 vs hv30/20
    By minidv2dvd in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 6th Feb 2009, 13:25
  5. Capturing Old MiniDV with Canon HV30
    By assman24 in forum Capturing
    Last Post: 14th Aug 2008, 01:41
