VideoHelp.com Forum
Results 1 to 15 of 15
Thread: DAT to MPEG 1
  1. Member MI6's Avatar
    How can I convert DAT file from video CD to MPEG 1 file.
    Regards
    QUALITY HAS A NAME
    This is very easy. Download and install the free VCDGear package. There is a setting in it to convert from DAT to MPEG-1. Note that DAT files are just MPEG-1 files with different headers, so the only "conversion" is to change the header information. The video is not actually re-encoded.
  3. Banned
    If there is only one MPG-video on the CD, then that's true. BUT if the (S)VCD
    contains several MPG clips, then the .DAT files and the actual MPG tracks
    not always are the same thing.
  4. Member MOVIEGEEK's Avatar
    All VCD's rename the MPEG files to AVSEQxx.DAT,all video files are kept in the MPEGAV folder.
    Most SVCD titles have the MPEG files named AVSEQxx.MPG,some SVCD have the files named AVSEQxx.DAT.All video files are kept in the MPEG folder.
  5. Member Alex_ander's Avatar
    Womble MVW works with .dat natively.
  6. Member p_l's Avatar
    Sometimes you can cheat and simply rename the file extension from .DAT to .MPG, but I'm sure somebody around here will come and wrap you on the knuckles.
    Midzuki - I bow to your knowledge, but I have NEVER (and I do buy VCDs) seen a VCD where a single MPG track spanned multiple DAT files. I'll have to take your word on it. I can't think of what you would possibly accomplish by doing that, even if the format supports it. What's the advantage?
  8. Member julitomg's Avatar
    You can also try ISOBuster (even the free version will allow you to do it)
  9. Banned
    Both jman98 and MOVIEGEEK --- please stop misunderstanding
    evrything I say
    I have created several non-standard VCDs and SVCDs with VCDImager itself,
    and such disks usually show there can be a difference between a .DAT on the
    filesystem and a physical track on the recordable layer of the CD. Maybe it's just
    the way VCDImager works in such situations, maybe there is no other way for
    authoring non-standard VCDs and SVCDs, or perhaps that's just what happens
    when a compact disc is supposed to contain over 15 MPEG clips ----
    ---- I really don't know which is the correct explanation to the "problem".
    I have extracted mpg from VCD using the VCDrip function in VCDEasy.
  11. Banned
    Just putting some more light onto the subject...
    The documentation of MPlayer says:
    About .DAT files. The ~600 MB file visible on the first track of the mounted VCD is not a real file! It is a so-called ISO gateway, created to allow Windows to handle such tracks ( Windows does not allow raw device-access to applications at all ). Under Linux you cannot copy or play such files (they contain garbage). Under Windows it is possible as its iso9660 driver [s:70e2f8e8f3]emulates[/s:70e2f8e8f3] attempts to emulate the raw reading of tracks in this file.
  12. Video Restorer lordsmurf's Avatar
    Because that fails a portion of the time. My experience put it as high as 25% of the time. Some higher, some lower.
  13. Member p_l's Avatar
    My bad, on two accounts. Yes, it is cheating and does fail from time to time, and that should have been "rap."
  14. Banned
    Well, here goes another (żnot-so-?) "amazing" "discovery".
    Just "out-of-curiousity", I started my PC with a Windows ME emergency floppy,
    and read the directory listing of the MPEGAV folder of one of my infamous
    XVCDs --- and soon afterwards, compared that listing with the output given by
    the cmd.exe of Windows XP. OK, the results are:
    [MS-DOS 8.0 --- command.com]
    .              <DIR>        14/07/80   0:00 .
    ..             <DIR>        14/07/80   0:00 ..
    AVSEQ01  DAT     5.150.720  14/07/80   0:00 AVSEQ01.DAT
    AVSEQ02  DAT     7.319.552  14/07/80   0:00 AVSEQ02.DAT
    AVSEQ03  DAT     5.023.744  14/07/80   0:00 AVSEQ03.DAT
    AVSEQ04  DAT     3.567.616  14/07/80   0:00 AVSEQ04.DAT
    AVSEQ05  DAT     6.064.128  14/07/80   0:00 AVSEQ05.DAT
    AVSEQ06  DAT     3.534.848  14/07/80   0:00 AVSEQ06.DAT
    AVSEQ07  DAT     2.764.800  14/07/80   0:00 AVSEQ07.DAT
    AVSEQ08  DAT     6.602.752  14/07/80   0:00 AVSEQ08.DAT
    AVSEQ09  DAT     4.655.104  14/07/80   0:00 AVSEQ09.DAT
    AVSEQ10  DAT    30.072.832  14/07/80   0:00 AVSEQ10.DAT
    AVSEQ11  DAT     9.678.848  14/07/80   0:00 AVSEQ11.DAT
    AVSEQ12  DAT   163.452.928  14/07/80   0:00 AVSEQ12.DAT
    AVSEQ13  DAT     3.280.896  14/07/80   0:00 AVSEQ13.DAT
    AVSEQ14  DAT   361.691.136  14/07/80   0:00 AVSEQ14.DAT
    AVSEQ15  DAT    66.402.304  14/07/80   0:00 AVSEQ15.DAT
    [WinXP cmd.exe]
    13/07/1978  21:00    <DIR>          .
    13/07/1978  21:00    <DIR>          ..
    13/07/1978  21:00         5.915.324 AVSEQ01.DAT
    13/07/1978  21:00         8.406.092 AVSEQ02.DAT
    13/07/1978  21:00         5.769.500 AVSEQ03.DAT
    13/07/1978  21:00         4.097.228 AVSEQ04.DAT
    13/07/1978  21:00         6.964.316 AVSEQ05.DAT
    13/07/1978  21:00         4.059.596 AVSEQ06.DAT
    13/07/1978  21:00         3.175.244 AVSEQ07.DAT
    13/07/1978  21:00         7.582.892 AVSEQ08.DAT
    13/07/1978  21:00         5.346.140 AVSEQ09.DAT
    13/07/1978  21:00        34.536.812 AVSEQ10.DAT
    13/07/1978  21:00        11.115.596 AVSEQ11.DAT
    13/07/1978  21:00       187.715.516 AVSEQ12.DAT
    13/07/1978  21:00         3.767.948 AVSEQ13.DAT
    13/07/1978  21:00       415.379.708 AVSEQ14.DAT
    13/07/1978  21:00        76.258.940 AVSEQ15.DAT
  1. VCD Karaoke (MPEG DAT file)- removing the vocals
    By tsrusa2002 in forum Video Conversion
    Last Post: 22nd May 2011, 02:51
  2. Replies: 0
    Last Post: 11th Mar 2010, 12:57
  3. convert VCD.DAT/MPEG to RMVb with dual channel audio
    By newbievideohelp in forum Video Conversion
    Last Post: 6th Nov 2008, 23:42
  4. How to corp a dat or mpeg file to mpeg
    By onlyrasel in forum VCDEasy General
    Last Post: 26th Sep 2008, 23:18
  5. dat to mpeg - no sound
    By goshz in forum Newbie / General discussions
    Last Post: 22nd Jun 2007, 04:24
