I tried GSpot but it gives the mpeg contained bitrate which always shows 10080 kbps. I wish to know the indicidual bitrates of the video and audio tracks. What tool can i use for this?? I need to find the bitrate of an already recorded DVD
The latest g-spot will tell you the header value (often wrong) in the left-hand pane, but it will tell you the true average bitrate on the right-hand side. It will also tell you the audio bitrates in the audio section (bottom left). If you watch it scan through the VOB you will get a feel for the fluctuation of birate because you can watch the numbers as it scans the video.
How to determine if a mkv / avi / whatever file is constant or avg bitrate?
By smackyourfupa in forum Newbie / General discussionsReplies: 3Last Post: 8th Oct 2011, 05:26 -
ways to determine the bitrate of your dvd to xvid or h264 encodes
By codemaster in forum DVD RippingReplies: 2Last Post: 21st Sep 2011, 21:25 -
Best tool to determine if DVD is hard telecined
By gminnick in forum DVD RippingReplies: 3Last Post: 6th May 2009, 03:50 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34 -
Determine best bitrate for a given resolution
By cd090580 in forum Newbie / General discussionsReplies: 7Last Post: 29th Oct 2008, 16:32
Statistics
Newest guides
Latest tool updates
New media comments
