VideoHelp.com Forum
    When i using Devede to make my dvd it's ok if i choose a english subtitle but when i choose Vietnamese or Chinese subtitle it was error and show the table:
    It seems to be bug of SPUMUX
    What should i do in this situation ?
    Any help will be greatly appreciate !
    Sorry for my English
    No one helps me
  3. Member Ethlred's Avatar
    Haven't tried that program BUT I have a suspicion as to the problem anyway. Since the English worked that is. The English might be ASCII and the other languages you tried are more likely Unicode. Don't know what to do about it though.
    I had that issue too, and other issues since switching to version 8.04, I guess the smart thing would be to go back to 7.10, I never had any problems with that. And a FYI if you try to run a virtual machin on 8.04 you'll have a very hard time being everything in the install channel crashes and doesn't run at all at times.
    Are there any software supported GUI for making DVD video in Linux can add Vietnamese or Chinese subtitle ?
  1. Replies: 8
    Last Post: 7th Mar 2011, 11:02
  2. Replies: 1
    Last Post: 31st Dec 2009, 16:20
  3. Replies: 1
    Last Post: 23rd Oct 2008, 18:48
  4. Changing DeVeDe default settings
    By henrik.uggla in forum Linux
    Last Post: 25th Jun 2007, 13:29
  5. Replies: 32
    Last Post: 11th Jun 2007, 00:51
