VideoHelp.com Forum
Closed Thread
Results 1 to 30 of 50
    Sam's has Verbatim DL 50 pack for around $60 with MIS or MII which varies by location; go to http://club.cdfreaks.com/f58/verbati...s-club-244555/ to see more discussion on this Sam's deal.
    Not a Sam's Club member, so I'd like to see this turn up elsewhere . . . but it sounds like this might be some pack that is exclusive to them ? It would have to be somewhere B&M, where it's possible to inspect the packaging: MII is apt to be throwing your money away.
    When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
    Those who are members can inspect packaging, and I plan to check my local store tomorrow. If you know somebody who is a Sam's Club member, you could ask them to check for you or go with them and have them buy for you if you find MIS. At the CDFreaks link in my first post some are finding only MII while others are finding MIS.
  4. Hello Ladies stiltman's Avatar
    I just got back from there, went for something else though.
    At this Sams, they were all MIS on the top shelf and all MIT on the second. They all looked exactly the same. BTW they said 2.4X non-printable
    I also noticed Sams only carries *Printable* media for CDs and DVD-+Rs
    Originally Posted by jagabo
    Which are rated better. Anyone know?
    The taiwan or singapore?
    MII = Made In Indonesia?
    -PB
  6. Member ricoman's Avatar
    MII - Made in India, stay away from these. MIS is good, never tried MIT DL, didn't know they made them there.
    I love children, girl children... about 16-40
    W.C. Fields
  7. Originally Posted by ricoman
    ...never tried MIT DL, didn't know they made them there.
    They don't. Anyone who thinks they saw MIT DL Verbatim is hallucinating. It's MIS or MII only.
  8. Member dutchdummy's Avatar
    As of July 30th, they're still there for that price, at least here in Fountain Valley, CA. I noticed that they were MIS.
    Sorry, Negritude, but the Sams club in Atlanta, about 6 months ago, had MIT DL's. I bought 2 packs of them. Right now, they only have the MIS DL's. They were 59.00 or so then, and are still the same price.
    Matt
  10. Hello Ladies stiltman's Avatar
    I guess I have good drugs or I'm blind and didn't know it.
    I report what I see as I see it.
    Next time I go to Sams, I'll look again. I only buy Printable DataLife Plus 2.4x DLs, so I wont be able to scan the ones at Sams
  11. Roadrunner JohnnyBob's Avatar
    Don't assume that MIS are good discs. I got a bad spindle of 95310 from Newegg earlier this year.
    I think the best advice is to get the 8x discs such as 96542. I've bought two batches of them and both were OK. Yes, they were made in Singapore, but that's no longer a guarantee of good quality.
  12. Member Noahtuck's Avatar
    Don't assume the quality of the MIS disc's was the issue 8)
    Originally a member since 2001, LONG LIVE TARAN's!!!
  13. Hello Ladies stiltman's Avatar
    I just don't assume
  14. Roadrunner JohnnyBob's Avatar
    Of course it was! Buying Verbatim DL discs has been turned into a crap shoot. They used to be reliable but not anymore.
  15. Hello Ladies stiltman's Avatar
    I only use these and I've never had a problem with them...none, ziltch, nada
    http://www.meritline.com/verbatim-6x...--p-18457.aspx
    http://www.supermediastore.com/verba...23-20pack.html
    http://www.rima.com/Merchant2/mercha...ory_Code=DVPVB
    So much for crap shoots
  16. Member Noahtuck's Avatar
    All i've ever used is MIS 2.4x DL+R's
    Both 2.4x 20 packs i bought from newegg over the last couple of months all burned and played perfectly.
    Except 2, and it was not the disc's fault that they ended up bad 8)
  17. Hello Ladies stiltman's Avatar
    SMS is cheaper by $0.98 for me
    However, That's the best price I've seen from newegg and it's 3 day too...
  18. Member
    I remember going to Sam's Club about a year ago or so after reading this topic. I remember seeing a few huge boxes of these but they were all mixed with where they were made. I don't remember which ones I got though so can someone tell me? Was it Singapore that was good or was it India? I think it was Singapore but I totally can't remember.
  19. Roadrunner JohnnyBob's Avatar
    It doesn't matter where they're made anymore, they're all equally unreliable. The game has changed.
    This seems to be your own rather-out-of-the-mainstream opinion. I'm as critical as anyone about such things, when there is good reason to be, but the MIS Verb DL have yet to give me any reason to be. I'm not going to base it on scans from your highly questionable methodology either: for my money, the only test that matters is whether the recorded content is still there and still readily accessible (on various optical readers / players, without a significant glitch) several years down the line. And the jury is still out on that one. If there is going to be a problem, not enough time has elapsed yet to reveal it.
    I've seen a few DVDs go south for me, but none of those were Verb DLs. (The only possible exceptions being a couple I know were badly made, using a poor choice of software to make them. But I learned from those mistakes.)
    I would expect MIT DL media to be excellent. Verbatim's single layer DataLifePlus series, which are excellent, are only made in Taiwan.
    For those who don't know, JohnnyBob had a rather staggering number of bad burns on his Verbatim DL media (was it something like 100?) and refused to consider that something else (his process, the burner, etc.) might be to blame. Every time anyone posts about Verbatim DL media, he posts to tell us how bad he thinks all Verbatim DL media is.
  22. DVD Ninja budz's Avatar
    I just bought a spindle of DL Verbatim from Sam's a few weeks ago. Burned some of them with no problems in playing back with any of my dvd players including my Panny BD35 Blu-ray player. I backed up my UP movie by doing a blu-ray conversion and burned it to DL. I burned the DL disc in my old Benq 1640 & Pioneer 216 dvd burner's!
  23. Video Restorer lordsmurf's Avatar
    Baloney.
    You've already been discredited twice on this topic:
    http://forum.videohelp.com/threads/3...a-should-I-use
    http://forum.videohelp.com/threads/3...Verbatim-discs
    Both myself and VegasBud outlined it quite in depth.
  24. Roadrunner JohnnyBob's Avatar
    I'm not a fish and do not swim in any stream. I use various testing procedures based on my long experience, and there is no jury involved. I am the sole judge of what has proven to be reliable for me! Let each run their own tests and judge for themselves...and not be dictated to by a few pseudo-gurus.
    Absolutely wrong! I have never made any such claims. Yes, I tend to respond negatively to dreamy-eyed pro-Verbatim DL folks who are basing their comments on the outdated distant past (over 2 years ago), not the present situation. The single-layer Verbatims are still excellent, but not the DL variety. Buying and using Verbatim DL's is a crap shoot now. Maybe you'll get lucky, but probably less so as time goes on, if they continue to decline in quality at the same rate as the last 2 years. Folks would be well-advised to switch to a different data backup method such as multi-TB external hard drives.
    Baloney.
    You two pseudo-gurus think you can hide the truth about Verbatim DL's for your own reasons, and I really can't guess your motivation. It's not a matter of credit or discredit. Anyone with Nero CD/DVD Speed, Opti Drive Control, BurnPlot, DVD InfoPro, or similar software can run their own tests and prove for themselves what is correct on this subject.
  25. DVD Ninja budz's Avatar
    Basically if the DL disc doesn't playback correctly it doesn't mean it's the media, it could be the dvd burner.
    Welps, I'm not going to get into a pissing match about it. The Sams club Verbatim DL media works for me and that's all that freaking matters.
  26. Originally Posted by JohnnyBob View Post
    If I remember correctly, you have issues with Verbatim SL media as well..not reliable "batch to batch" as you say. Since you rely so heavily on worthless disc scans to form your opinions, I think maybe you should heed your own advice and go the external hard drive route, save yourself a lot of time and grief. No one on this site has had as many problems with DL/SL optical media as you, not even close, clearly something is wrong with your process.
    Personally, I've never had any issues whatsoever with Verbatim DL media and I've burned a lot of them. Verbatim DL+ImgBurn+quality DVD/Blu-ray player = flawless perfection.
    Nothing wrong with the external hard drive option though, I have everything backed up to both optical disc AND external hard drive as I would never trust anything backed up on hard drive alone. The hard drive option is appealing as a space saving option and also, media players are the future IMO.
  27. Roadrunner JohnnyBob's Avatar
    You don't remember correctly... I've only bought one spindle of 100 Verbatim DVD-R single layer and they are excellent, better than the Taiyo Yuden that I always used before. I've had some batches of TY that were of lower quality.
    Disc scans with appropriate software are not worthless, and there is nothing wrong with my burning processes. I use Imgburn too. You are mis-stating or mis-understanding the facts. I have not claimed massive burn failures with any of these discs. It's a matter of relative quality of different batches of the various discs, and clearly Verbatim DL is on the decline. I expect we'll see the difference more dramatically soon as their quality control implodes completely.
    P.S. I continue to test and just bought a spindle of Verbatim DL from newegg. They're the worst yet with quality scores at or near zero(0). Yes, they burn and verify but it's a miracle. I certainly won't put anything important on them.
  28. DVD Ninja budz's Avatar
    ^^^If you're burning dvd discs with that Liteon drive that's posted in your profile that could be the culprit. I've never trusted LITEON drives for burning dvd media. I only use LITEON's for ripping purposes. Just my 2 freaking cents!
  29. Member
    Just my $.02: having burned over 100 Verbatim DL discs, I have only had ONE coaster that wasn't caused by human (namely, mine) error. All of these have been Made in Singapore, and all of them work to this day. I have never bought any MII or MIT Verbatim DLs (didn't even know they had Made in Taiwan Verbatim DLs)
  1. Replies: 2
    Last Post: 8th Sep 2010, 07:51
  2. No More Verbatim at Sam's Club
    By wulf109 in forum Media
    Last Post: 26th Aug 2010, 12:58
  3. Replies: 13
    Last Post: 19th May 2008, 17:06
  4. Replies: 5
    Last Post: 16th Mar 2008, 20:46
  5. Replies: 2
    Last Post: 31st May 2007, 19:07
