Anyone know if the NTSC and PAL versions of this camera really is different? BH Photo have two versions, a NTSC and a PAL at a much higher price, while Electronic King Inc. sells the camera on eBay with the following statement: "Item is compatible worldwide (110-240V & PAL/NTSC)".
Could the NTSC/PAL thing just be a different power plug for the charger and a way to be able to price the camera different in the two parts of the world?
If anyone has the camera (or a HF100), is it possible to set the camera to NTSC and PAL in the menu, and is it correct that the charger is 110-240V?
Thread: Canon HF10 NTSC or PAL
You could download the manual or other info from Canon. This is from Canon USA: http://www.usa.canon.com/consumer/co...nloadDetailAct
You should be able to find the PAL version from Canon Global: http://www.canon.com/
If it's like the HV20/HV30, it's not possible to switch. "NTSC" = 60,30, and 24 fps; "PAL" = 50 and 25 fps.
(where fps = frames or fields per second, as appropriate).
Cheers,
David.
From my experience, most video cameras have chargers which will work anywhere in the world (110V-240V).
The crux of the matter is which TV system you use. PAL or NTSC.
Canon HF10 vs HF20
By jazu in forum Camcorders (DV/HDV/AVCHD)Replies: 15Last Post: 2nd Jun 2010, 12:29 -
Canon HF10 -> Premiere Elements 7.0
By Jone.T in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 12th Dec 2008, 05:21 -
Canon HF10 - 50i or 25p ?
By theaterguy in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 17th Nov 2008, 01:57 -
Canon HF10 und Sony Vegas
By miepel in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 19th Apr 2008, 15:27 -
When will the Canon HF10 and HF100 be available to buy online ?
By thecuban in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 8th Jan 2008, 09:31
Statistics
Newest guides
Latest tool updates
New media comments
