hi -
i've recently purchased an AG-8700 with built in TBC and whenever I switch the TBC on the image on screen turns brightly coloured, usually all a shade of reddy brown or a mixture of blue and purple!
i have the manual and menu settings and can't see anything that suggests I've set it up incorrectly...
any hints or have I got a faulty VCR?
the head hours are 222... I've heard about leaky capacitor problems with some panasonic decks
thanks
adrian
Thread: panasonic ag 8700 TBC problem
Hello!
I guess maybe your tbc is somehow misconfigured?
I noticed inside my unit that on TBC and TBC2 cards are lot of trimmers with what you can adjust signal parameters etc. Most of these are easyly accessible without card removal and have short explanations beside. About this should be written in service manual.
I have the ag-8600 player only, and if I switch tbc on, picture freezes.
If you have ag-8700 manual in electronic form, can you share it with me?
Panasonic AG-7500 - does it have TBC?
By Gibson's Squares in forum RestorationReplies: 5Last Post: 8th Apr 2011, 22:35 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum CapturingReplies: 8Last Post: 15th Jan 2011, 09:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
Nippotec MT-8700
By brianstivala in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Apr 2008, 12:20 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 08:29
Statistics
Newest guides
Latest tool updates
New media comments
