VideoHelp.com Forum
    A month ago I bought a Panasonic HDC-SD5 high definition camcorder. After some problems getting
    the AVCHD material to my Imac I found out that the convertor in Toast 9 was doing the job well.
    Now I want to go in the other direction from the Imac to the Camcorder or better, from Final Cut Pro6
    to the camcorder. Is there any possibility to convert Quicktime compatible High def video material
    (say) HDV to AVCHD? I want to bring back my HD mastervideo to the camcorder and use this small
    device as a HD videoplayer. I want to take with me the edited versions from FCP and put this back to
    the 16GB SDHC card and show this via the component or HDMI on any flatscreen or beamer.
    Who did this, or who can give me advice? I don't want to buy a HD mediaplayer when my camcorder
    can do the job.
    Thanx
    Hi,
    You might want to try RevolverHD http://shedworx.com/?q=revolverhdmac available from ShedWorx. It takes your FC files and converts them to an MTS file (AVCHD) file.
    One thing to keep in mind is there are variations with AVCHD files depending on the camera it came from. AVCHD is still a work in progress and as a result, there are significant variations in AVCHD files from one brand of camera to another. Not only that, but succeeding models from any given manufacturer have variations in the AVCHD files as well. As a result, some of these AVCHD variations don't work in some software tools.
    There are various problems such as motion artifacts that the camera manufactures are trying to deal with. Since it's a competitive market, the various camera manufacturers aren't too eager to help their competition with their latest and greatest enhancements.
    One of the problems is insufficient bit rate to adequately support AVCHD. I suspect there are hardware constraints in the cameras to keep the cost down. AVCHD takes a lot of processing power and processing power equals cost. I suspect there is a lot of debate going on within the camcorder manufactures about how to balance this with one camp saying "speed up the camcorder hardware" and the other camp saying, "Make a better CODEC."
    Just be mindful that AVCHD is not all of the way there yet and there are some land mines and bear traps that can be frustrating when using AVCHD files. Since there is no "one" standard AVCHD format, you may have a problem with your objective of importing an AVCHD file into your camcorder - The camera may not recognize the particular variant of AVCHD that you import.
    Thanx Philg08. I downloaded RevolverHD for Mac but I could do no settings in the demo mode.
    And they don't explain anything special about the advantages of this program.
    SCDVD- you got a point with your reaction on this AVCHD "standard".
    I try with my Mac to write back AVCHD files to this specific Panasonic camera.
    So I have to encode my FCP files to the format I show below (MediaInfo Mac):
    *** MediaInfo Mac // Plain text file report
    2008-06-23 13:46:29 +0200
    Information for File: 00002.MTS
    General / Container Stream # 1
    Total Video Streams for this File -> 1
    Total Audio Streams for this File -> 1
    Video Codecs Used -> AVC
    Audio Codecs Used -> AC3
    File Format -> BluRay Video
    Total File Size -> 16.1 MiB
    Video Stream # 1
    Codec -> AVC
    Codec (Human Name) -> Advanced Video Codec
    Codec Profile -> High@L4.0
    Frame Width -> 1920 pixels
    Frame Height -> 1080 pixels
    Frame Rate -> 25.000 fps
    Display Aspect Ratio -> 16/9
    Interlacement -> Top Field First
    Codec Settings (Summary) -> CABAC / 2 Ref Frames
    Codec Settings (CABAC) -> Yes
    Audio Stream # 1
    Codec -> AC3
    Audio Stream BitRate -> 256 Kbps
    Audio Stream BitRate Mode -> CBR
    Number of Audio Channels -> 2
    Audio Channel's Positions -> L R
    Sampling Rate -> 48.0 KHz
    Audio Stream Delay -> 2s 316ms
    Special is the CABAC codec with 2 Ref Frames
    The other settings are no problem; I can manage that.
    Question is: What program can handel the CABAC codec?
  1. avchd copy to mac
    By thomas basham in forum Mac
    Last Post: 22nd Jul 2010, 12:35
  2. Replies: 5
    Last Post: 10th Jan 2010, 12:56
  3. Replies: 3
    Last Post: 23rd Nov 2009, 12:31
  4. Replies: 0
    Last Post: 14th Nov 2009, 23:11
  5. Creating an AVCHD DVD disc on a mac
    By mattr in forum Mac
    Last Post: 31st Oct 2009, 04:59
