VideoHelp.com Forum
Results 1 to 12 of 12
    I have a I have a LG GSA-H55N drive. I can load DVD-R/W and CD-R/W and even bought music CD's, but I can't load professional protected bought DVDs.
    I was able to a few months ago, but now I can't load any.
    So, I can't burn DVD's. I can load DVD-R/W and CD-R/W and even bought music CD's, but I can't load professional protected bought DVDs.
    So, I can't burn DVD's. I have recently updated the driver from 1.02 to 1.05, but it still didn't help.
    check that the region code of the drive is set to your area. drive/properties/hardware(drive)/properities/dvd region.
    Yeah, I have checked that before. It is the correct region.
  4. Member Krispy Kritter's Avatar
    What actual error do you get when you insert a movie DVD? What software is giving you the error? Can you view/browse the DVD contents within Windows Explorer or My Computer?
    Google is your Friend
    I mainly want to rip and burn DVD's and view DVD's, which I have been able to view before. I don't actually get errors when I put in a movie DVD, but most of the time, the DVD doesn't even load, meaning it doesn't even show in 'MyComputer' under the DVD drive.
    The errors I get are when I try to rip the movie for burning.
    This is my problem with ripping, which I think may have something to do with the drive. Below is about the ripping problems I have....
    __________________________________________________ ________
    I have been burning and ripping DVD's using my "LG GSA-H55N" drive.
    For the first few months of this year it has been burning perfectly with
    DVD43, DVD Shrink, Nero Express, but in the last few months it doesn't
    work with anything. I get heaps of errors.
    I have tried DVD Decrypter, AnyDVD etc, but I always get errors.
    I have mixed software I use and every time I get errors.
    I have uninstall and reinstalled various softwares a number of time.
    Some error messages I get are...
    "Invalid DVD navigation structure"
    "I/O"
    "Pure virtual function call'"
    "Data error (cyclic redundancy check)"
    My computer froze for a while and I got it fixed,
    then got it back and it worked perfectly for a little while,
    then suddenly stopped working and the errors came.
    I have tried heaps of google searches and read forums and
    tried to find a patch, but I don't understand anything I have found.
    The drive doesn't seem to load protected DVD's and
    when it does it takes a long time.
    Also I am unemployed, so I can't buy anything unless I can be 100%
    sure that it works and it doesn't cost much. So, I am relying on 100%
    freeware.
    I have updated the drive, successfully, from 1.02 to 1.05
    and it still doesn't work.
    So can anyone help me with a patch?
    Does it need something to do with ASPI or RPC,
    these came up in error messages...
    and if so can anyone provide me with a link for Freeware?
    I am getting really annoyed and losing my patience.
    I am running Vista, so can anybody help me, please.
    This is getting me very annoyed - any help would be greatly appreciated.
  6. Member [_chef_]'s Avatar
    Your vista is crapped, and the dvds are copy protected.
    Try in safe mode.
    *** Now that you have read me, do some other things. ***
    I am still unable to continually burn DVD's. I am able to burn the occasional one, but at first the DVD doesn't load at all.
    Sometimes the DVD loads ok, but then half way through burning it just stops. None of my DVD's show up on "My Computer".
    Protections are not the the problem because I have AnyDVD.
    The main problem is that professionally made DVD's don't show up,
    but DVD-R/RW, CD-R/RW and professionally made music CD's do work.
    Please can anyone help me - I am really frustrated about it.
  8. Banned
    As _chef_ said, probably your Vista is rotten.
    Try a registry cleaning, or a fresh re-install.
    But if you have already done it,
    then the problem is in the DVD-drive itself.
    I don't think it's Vista. I think it may be the drive.
    It's still under warranty, but I hate to leave it at the computer
    place for like a week.
    What do you mean a re-install? How would I do that?
  10. DVD Ninja budz's Avatar
    reinstall your operating system, "VISTA". or buy a new dvd burner which is cheap these days. buy a PIONEER 115 or 116 dvd burner.
    I bought a LG blu Ray dvd burner last year, and I had to send it for repair 3 times so far. LG's equality is just not there. Get a pioneer 115 which I burn over 1000 pcs already.
    Amazon is selling it for 26 dollars.
    http://www.amazon.com/gp/offer-listi...8136407&sr=8-1
    As I am unemployed I can't buy another DVD drive.
    I have tried it on Safe Mode and it still doesn't load.
    I have cleaned the registry etc and it still doesn't load.
    What's very weird is that I can load burnt DVD's, bought music CD's
    CD-R, CD-RW, DVD-R and DVD-RW, just not
    protected bought ones.
    Also it's weird that very rarely one just loads.
    Any ideas?
  1. Audacity doesn't load wav from Premiere
    By Instant Martian in forum Audio
    Last Post: 12th Jun 2010, 10:26
  2. BSOD - Window doesn't load normal/safe mode
    By hoon88 in forum Computer
    Last Post: 25th Oct 2009, 07:49
  3. LG GSA H55N region free?
    By Ace-Of-Spades in forum DVD & Blu-ray Writers
    Last Post: 6th Feb 2009, 08:18
  4. Drive problem- LG GSA-H10L
    By pinetop in forum Computer
    Last Post: 17th Apr 2008, 01:39
  5. should I install LG GSA-H55N firmware update 1.02 (July 2007)?
    By JohnnyBob in forum DVD & Blu-ray Writers
    Last Post: 17th Aug 2007, 23:12
