i tried to play these movie files(over 7 gigas....) in my pc............but it plays very slow........when i download files half size....they play ok..........i tried so far almost every player avaliable....but the big files have these gaps,the video is very slow,the audio have no problem...........my pc is a pentium 4,3gigas cpu,4gigas ram,and a nvidia 8600 GTS graphics card.......................i checked the cpu used while playing........and its about in 60%...............and almost nothing is running in the background,except for the antivirus (AVG).i have download every codec needed for..............i would appreciate some help!!!!!!!!!!!!!!!!!!!!!!!!!!ah..the files are these matroska files......(blue ray format movies.....)
Thread: matroska files playing problems
Buy the originals or make backups from your OWN discs...Originally Posted by pepevideo
Try using VLC to play it and see if it's better. Unless you have a dual core or better CPU, MKV playback of high definition video will be a big problem. If you have a single core CPU, you don't have enough CPU power to play 1080p MKV files. 720p might play OK though. Also, if your PC monitor does not go up to resolution 1920x1080 or higher, whatever software player you have may be trying to resize any 1080p video and that will not help.
my monitor has no problems..........well i was thinking yeah it maybe better to upgrade my cpu.........besides i have no problems playing files at 720p.........the 1080p are the trouble...any way thanks for the advise......
CCCP
I am surprised that nobody has added the CCCP filter pack to the TOOLS on this forum???
It's a great package that installs Media Player Classic, ffdshow, Haali's Media Splitter and other items. I usually don't recommend installing codec/filter packs but this one is the exception.
Get the software here:
http://www.cccp-project.net/
FAQ
http://www.cccp-project.net/wiki/index.php?title=FAQ
The CCCP (Combined Community Codec Pack) is a DirectShow filter pack.
What is the CCCP?
The full title is the Combined Community Codec Pack. Actually, it's more like a filter pack than a codec pack but filter doesn't begin with C and we wanted a good acronym. The name is also a pun on the Russian name which is transliterated into the Latin alphabet as "Soyuz Sovietskikh Sotsialisticheskikh Respublik", or "Union of Soviet Socialist Republics", abbreviated as "CCCP" or "USSR". Blame Lenin and the Commies.
Jokes aside, the CCCP was created to replace the filter packs provided by several anime fansub groups into a single reliable pack capable of decoding practically any group's files - without breaking compatibility for other formats. Since then we've grown into a pack that can decode more or less anything that you will run into during your travels on the internet. We're supported and endorsed by a number of groups...
Demux Matroska files
By Anicsi in forum MacReplies: 4Last Post: 16th Dec 2009, 12:41 -
How Can I convert Matroska files without losing both 2 audio and 2 subs?
By shuyinliquid in forum Video ConversionReplies: 1Last Post: 9th Apr 2009, 13:58 -
Problems playing avi files with subtitles
By EPK in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2008, 21:56 -
Another conundrum! How to burn Matroska HD files to DVD-R?
By expat in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2007, 14:02 -
Problem playing .mkv (matroska)
By mk2006 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2007, 04:33
