VideoHelp.com Forum
    Goal:
    Rip my entire collection of DVDs and Blu-Rays, including menus, audio channels, subtitles, etc. Basically, I'd like a perfect copy of each movie in *some form*. These would (hopefully) be browsable and streamable over my network via a Popcorn Hour unit.
    Based on what I've read and searched on, I *think* it's simply a matter of ripping the movie to an iso image. I'm not concerned about hard disk space so I think re-encoding isn't an issue. I just want all the full functions as if I'm playing the actual DVD thru a standalone player.
    Any help or insight appreciated!
    TIA
  2. Member Krispy Kritter's Avatar
    The only real way to maintain menus, is by simply creating dvd images. But you will need to know if the Popcorn Hour unit supports them.
    Google is your Friend
    From reviews I've read, the Popcorn Hour player does support a lot of stuff, but I don't know about BluRay rips. DVD rips should be no problem though.
    Popcorn Hour won't play everything and expecting to stream BluRay to it may not be realistic. There's been some discussion in the past of the Popcorn Hour player in the forums at http://www.doom9.net, specifically in the Hardware Players section. If nobody here has any definitive answer, you might ask over there specifically about the BluRay part of your plan.
    Thanks very much guys. From looking into it I think that it probably won't do a full Blu-Ray rip as if it was in the drive so I may just convert them to an mkv or something.
    Again, thanks for the input!
  1. Replies: 4
    Last Post: 22nd Mar 2011, 04:50
  2. Ripping Blu Ray to Dual Layer DVD?
    By gbreeze in forum Blu-ray Ripping
    Last Post: 26th Dec 2009, 22:27
  3. Advice on buying a blu ray drive for HTPC
    By aberthol in forum DVD & Blu-ray Writers
    Last Post: 16th Dec 2009, 08:58
  4. Replies: 3
    Last Post: 11th May 2009, 18:48
  5. Want to archive my DVD library to my HTPC
    By Memo_182 in forum Media Center PC / MediaCenters
    Last Post: 26th May 2008, 19:45
