hi
i am trying to encode bluray and hddvds to 720p mkv's
i am using the autoencode to a size of 4.4gb but my finished muxed file is turning out at 400mb,500mb i have tried it a few times with the same outcome none of them are the output sie i select???i have also uninstalled and reinstalled but no effect i still dont get the same output size
i would be greatfulk for help
thank you
Thread: megui problem
What was the script used?
What was the video size, and audio size?
Post the MeGUI log here.
thank u for the reply
here is my log
Generating jobs. Desired size: 4.4 GB
Desired size of this job series: 4.4 GB
Split size of this job series: N/A
Looking for job processor for job...
Processor found!
Starting job job1 at 15:22:13
Starting preprocessing of job...
Preprocessing finished!
successfully started encoding
Processing ended at 16:32:28
Log for job job1
Input: Channels=6, BitsPerSample=16, SampleRate=48000Hz
Command line used: C:\Program Files\megui\tools\Nero\neroAacEnc.exe -ignorelength -lc -br 192000 -if - -of "C:\Documents and Settings\Compaq_Owner\Desktop\doom audio.m4a"**************************************** *********************
* Nero Digital Audio Reference MPEG-4 & 3GPP Audio Encoder *
* Copyright 2007 Nero AG *
* All Rights Reserved Worldwide *
* Package build date: Aug 6 2007 *
* Package version: 1.1.34.2 *
* See -help for a complete list of available parameters. *
Starting postprocessing of job...
Job completed successfully and deletion of intermediate files is activated
Postprocessing finished!
End of log for job1
Processor found!
Starting job job2 at 16:32:28
Doing bitrate calculation...
Desired video size after subtracting audio size is 4418854KBs. Setting the desired bitrate of the subsequent video jobs to 5352 kbit/s.
Processing ended at 21:57:11
Log for job job2
Job commandline: "C:\Program Files\megui\tools\x264\x264.exe" --pass 1 --bitrate 5352 --stats "C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.stats" --keyint 240 --min-keyint 24 --bframes 16 --b-pyramid --direct auto --filter 1,1 --subme 1 --partitions none --me dia --merange 12 --threads auto --thread-input --sar 641:625 --progress --no-psnr --no-ssim --output NUL "C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.avs"
avis [info]: 1280x720 @ 29.97 fps (202691 frames)
x264 [info]: using SAR=641/625
x264 [info]: using cpu capabilities: MMX MMX2 SSE SSE2 SSE3 3DNow
x264 [info]: slice I:875 Avg QP:10.59 size: 76465
x264 [info]: slice P:14579 Avg QP:10.74 size: 7451
x264 [info]: slice B:187237 Avg QP:10.84 size: 2307
x264 [info]: mb I I16..4: 48.6% 0.0% 51.4%
x264 [info]: mb P I16..4: 4.8% 0.0% 0.0% P16..4: 37.7% 0.0% 0.0% 0.0% 0.0% skip:57.5%
x264 [info]: mb B I16..4: 0.1% 0.0% 0.0% B16..8: 0.9% 0.0% 0.0% direct:34.8% skip:64.2%
x264 [info]: final ratefactor: -6.61
x264 [info]: direct mvs spatial:100.0% temporal:0.0%
x264 [info]: kb/s:718.6
encoded 202691 frames, 10.42 fps, 718.68 kb/s
End of log for job2
Processor found!
Starting job job3 at 21:57:11
Processing ended at 06:18:13
Log for job job3
Job commandline: "C:\Program Files\megui\tools\x264\x264.exe" --pass 2 --bitrate 5352 --stats "C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.stats" --keyint 240 --min-keyint 24 --ref 8 --mixed-refs --bframes 16 --b-pyramid --b-rdo --bime --weightb --direct auto --filter 1,1 --subme 6 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh --merange 12 --threads auto --thread-input --sar 641:625 --progress --no-psnr --no-ssim --output "C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.mkv" "C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.avs"
x264 [warning]: Error: 2pass curve failed to converge
x264 [warning]: target: 5352.00 kbit/s, expected: 936.69 kbit/s, avg QP: 10.0004
x264 [warning]: try reducing target bitrate or reducing qp_min (currently 10)
x264 [info]: slice I:875 Avg QP:10.52 size: 68509
x264 [info]: slice P:14579 Avg QP:10.32 size: 9477
x264 [info]: slice B:187237 Avg QP:11.82 size: 581
x264 [info]: mb I I16..4: 25.1% 60.8% 14.1%
x264 [info]: mb P I16..4: 1.2% 1.8% 0.9% P16..4: 33.1% 1.3% 1.2% 0.0% 0.0% skip:60.5%
x264 [info]: mb B I16..4: 0.0% 0.1% 0.0% B16..8: 0.8% 0.0% 0.1% direct: 0.1% skip:98.8%
x264 [info]: 8x8 transform intra:54.0% inter:62.8%
x264 [info]: direct mvs spatial:99.9% temporal:0.1%
x264 [info]: ref P 94.7% 2.0% 1.5% 0.5% 0.5% 0.3% 0.3% 0.2%
x264 [info]: ref B 78.5% 10.7% 5.2% 2.1% 1.6% 1.2% 0.6%
x264 [info]: kb/s:362.9
encoded 202691 frames, 6.75 fps, 363.98 kb/s
desired video bitrate of this job: 5352 kbit/s - obtained video bitrate (approximate): 366 kbit/s
Found intermediate output file 'C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.stats', deleting...
Deletion succeeded.
End of log for job3
Processor found!
Starting job job4 at 06:18:13
Processing ended at 06:19:51
Log for job job4
Job commandline: "C:\Program Files\megui\tools\mkvmerge\mkvmerge.exe" -o "C:\Documents and Settings\Compaq_Owner\Desktop\DOOM-muxed.mkv" --aspect-ratio 0:9117/5000 -A -S "C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.mkv" -a 1 -D -S "C:\Documents and Settings\Compaq_Owner\Desktop\doom audio.m4a" --no-clusters-in-meta-seek
mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:13
'C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.mkv': Using the Matroska demultiplexer.
'C:\Documents and Settings\Compaq_Owner\Desktop\doom audio.m4a': Using the Quicktime/MP4 demultiplexer.
'C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.mkv' track 1: Using the MPEG-4 part 10 (AVC) video output module.
Track 1 of 'C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.mkv': Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1313/720.
'C:\Documents and Settings\Compaq_Owner\Desktop\doom audio.m4a' track 1: Using the AAC output module.
Warning: 'C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.mkv': A track with the ID 0 was requested but not found in the file. The corresponding option will be ignored.
The file 'C:\Documents and Settings\Compaq_Owner\Desktop\DOOM-muxed.mkv' has been opened for writing.
The cue entries (the index) are being written...
Muxing took 95 seconds.
Found intermediate output file 'C:\Documents and Settings\Compaq_Owner\Desktop\DOOM.mkv', deleting...
Deletion succeeded.
Found intermediate output file 'C:\Documents and Settings\Compaq_Owner\Desktop\doom audio.m4a', deleting...
Deletion succeeded.
End of log for job4
MeGUI problem\help
By DeNeDe in forum Newbie / General discussionsReplies: 0Last Post: 4th Oct 2011, 08:29 -
MeGUI problem
By socrates in forum Video ConversionReplies: 0Last Post: 5th Jul 2011, 04:12 -
Problem with MeGUI
By gis4ever in forum Video ConversionReplies: 2Last Post: 9th Sep 2010, 07:03 -
problem with megui
By simonrule in forum Video ConversionReplies: 2Last Post: 3rd Dec 2009, 16:39 -
megui problem....
By cowboysroy31 in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2007, 13:27
Statistics
Newest guides
Latest tool updates
New media comments
