    I am trying to record from my tv which is attached to cable but when i am recording i periodically hear a glitch in the audio. It sounds like a fizz almost like it is distorting due to volume levels, but the audio going into the recorder is from a line out on the cable box and the audio glitch happens randomly but in close intervals. I have tried different audio sources but experience the same thing..
    Please help...
  2. Member Krispy Kritter's Avatar
    There isn't likely much that you can do. The only thing you can try is replacing the audio cable. If you always hear the noise, even when watching TV, then the problem is likely to be the cable box. If the noise is only present in your recordings, then the problem is likely your recorder. If it's under warranty, have it serviced, otherwise, it is likely cheaper to replace it.
    Google is your Friend
  1. Panasonic DMR-E80H recording quality question ?
    By tienquang2 in forum DVD & Blu-ray Recorders
    Last Post: 16th Dec 2004, 02:56
  2. Panasonic DMR E80H Question about FR recording
    By dvd-dude in forum DVD & Blu-ray Recorders
    Last Post: 26th Aug 2004, 14:26
  3. Panasonic E80H Recording VHS problem?
    By Redtop in forum Newbie / General discussions
    Last Post: 3rd Mar 2004, 15:19
  4. Panasonic DMR-E80H and DMR-E100HS remote control question
    By spiderman2k1 in forum DVD & Blu-ray Recorders
    Last Post: 14th Jan 2004, 10:31
  5. Panasonic DMR-E80H authoring process problem
    Last Post: 27th Dec 2003, 02:05
About   Advertise   Forum   RSS Feeds   Statistics   Tools
