i am encoding an hdmovie with ripbot to mkv with settings of 1280x720 to 23.973 to about 7 gigs. it takes 2 to 3 hours for the first pass then anywhere from 8 to 10 hours for the second pass. is there anyway to speed this process up without getting a quadcore computer. iam running a hp with 6400 dualcore processor and four gigs of ram with onboard video i have the ffdshow and hali installed and the klite and cccp installed. would a more powerful video card help out with encoding. thanks for your help.
Set it for CQ, which will be 1 pass. Tough to gauge output size, though.
okay soopafresh will try that will it still take 8 to 10 hours
soopafresh trying cq=22 but it shows pass1 is that right or will it do 2 pass it's showing about 7 and half hours
I don't know RipBot but if it is using a high motion estimation setting selecting a lower one may cut your encoding time in half. With CQ encoding the file will turn out a little bigger (5% maybe, depends on the particular video). With 2-pass VBR it will be the same size but a little lower in quality.
okay jagabo next time i do a movie i'll try it right now with cq=22 it's doing it in about 7 and half hours. i don't mind the length so much but it puts a load on my processor
If you're talking about the computer being hard to use (laggy) while encoding, try setting RipBot's priority lower with Task Manager.Originally Posted by zerocoool
updating the x264 revision within RipBot?
By shagratt71 in forum Video ConversionReplies: 0Last Post: 14th Dec 2011, 01:08 -
RipBot Encoding Wrong Language
By andy6590 in forum Blu-ray RippingReplies: 7Last Post: 1st Apr 2011, 15:20 -
RipBot 264 Speed
By Benjy in forum Video ConversionReplies: 10Last Post: 6th Nov 2009, 00:16 -
Ripbot problem, encoding terminated after 4 minutes
By marax in forum Blu-ray RippingReplies: 8Last Post: 14th Oct 2009, 12:11 -
ripbot x264 and the black border
By miss in forum Blu-ray RippingReplies: 2Last Post: 14th Jul 2009, 12:30
