  1. Member gooberguy's Avatar
    Hello!
    i bought this motherboard and this fan for it, but it happens to be that the heatsink/fan would not fit in the slot over the CPU.
    my question is can anyone link me to a cheap heatsink/fan that would fit?
    thanks
    Just check the site you linked to for a socket 754 fan/heatsink.
    The specs for the motheboard (again from that link) tell you that info.
  3. DVD Ninja budz's Avatar
    http://www.newegg.com/Product/Produc...k=&srchInDesc=
    here's a link on what hsf you could use on your socket 754 mobo.
  4. Member gooberguy's Avatar
    thanks a lot, i was having trouble because, the socket on the mobo was just 754 while as the categories under newegg had 754+ some others.
    Also be sure the cooler will fit in your case.
  6. Mod Neophyte Super Moderator redwudz's Avatar
    The one you originally linked to appears to be for a Socket A (Socket 462) CPU. You can tell by the 'ledge' on one side of the cooler base. The 462 doesn't have the large heat spreader covering the CPU module like the newer CPUs use.
  1. Heatsink and Fan
    By lifesajrny in forum Computer
    Last Post: 16th Apr 2005, 22:09
  2. Need a Heatsink Fan!!!
    By nytramlean in forum Computer
    Last Post: 4th Apr 2004, 23:33
  3. Overclocking 2500+ - heatsink/fan?
    By mujahid7ia in forum Computer
    Last Post: 4th Feb 2004, 16:43
  4. Need P4 cooling fan/heatsink advice...
    By etecnifibre in forum Computer
    Last Post: 11th Oct 2003, 09:12
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
