Ok, I finally after months of trying was able to capture with my Saa7134 card/driver (cheapie $20 job) with audio and video in sync, only with mencoder.
Here is what I use:
Code:mencoder -oac mp3lame -ovc lavc -lameopts mode=1:vbr=2:q=4 -lavcopts vcodec=mjpeg -tv driver=v4l2:norm=ntsc:channel=3:adevice=/dev/dsp:amode=1:width=640:height=480 -af volume=-20 -o tv.avi tv://
However, it seems that my card flips the fields. The only way that seems to make it look good on the tv is to deinterlace.
Here is what I use to convert it into a DVD format. I edit this then with avidemux, just copying. Seems to work
Now, the only thing is that video seems to have a "film" look now, which isn't bad, but it isn't what I expected. Having audio in sync was priority one. Non-Jittery video was priority two.Code:mencoder -oac lavc -ovc lavc -of mpeg -mpegopts format=dvd:tsaf -vf pp=li/ha/va/dr,hqdn3d,scale=720:480,harddup -srate 48000 -af lavcresample=48000 -lavcopts vcodec=mpeg2video:vrc_buf_size=1835:vrc_maxrate=9800:vbitrate=5000:keyint=18:vstrict=0:acodec=ac3:abitrate=192:aspect=4/3 -ofps 30000/1001 -o
Is it because of using the linear interpolation to deinterlace? Should I use something else? I tried a few ways to flip the fields, but nothing seemed to work, and it seemed like to much trouble for VHS...
Any suggestions?
Thanks in advance!
Kris
No ideas?
While it isn't a linux app you might try restream. It can easily change the field order. Useful in situations like yours. I used to use it a long time ago when an Ati card I had capped bottom field first. I used restream to set the stream to tff. IIRC it only works on elementary video streams so you will have to demux first.
I haven't tried it myself but you might try installing it through wine. It's worth a shot.Donadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
Converting non-utf8 .ass to .srt in linux
By p014k in forum SubtitleReplies: 5Last Post: 22nd Apr 2011, 08:20 -
Linux compatible SD capture
By dewdude in forum CapturingReplies: 8Last Post: 17th Sep 2010, 20:57 -
MKV oddities
By Alexstarfire in forum Video ConversionReplies: 0Last Post: 13th Jul 2010, 11:44 -
Converting VHS to DVD under Linux HOWTO
By danboid in forum LinuxReplies: 19Last Post: 21st Jun 2010, 06:35 -
Converting video of any format to MOV or MP4 Linux/Debian
By lordshadow in forum Newbie / General discussionsReplies: 11Last Post: 31st Aug 2008, 10:35
Statistics
Newest guides
Latest tool updates
New media comments
