Hello community, Is it possible to append segments of a 2 part Bin/Cue folder? The files I have are in 2 folders, CD1 and CD2 both folders contain a Bin and a Cue file. Could vcdgear do this?
Seek, And You Shall Find.
You have to extract the contents, then combine them. What you have are the images of two different CDs.
What do you want to do with the combine content ?
Hi Guns1, hope all is well.
I wanted to create a dvd from the images. I did manage to convert the Bin files to .mpg in vcdgear but became confused with handling the audio.Seek, And You Shall Find.
Simplest method is Tmpgeenc DVD Author, which will automatically upsample the audio from VCD's 44.1 to DVD's 48 kHz, and easily allow you to put both halves on the same title for virtually seamless playback.
OK I will give it a try and post back. Thanks Guns1inger
EDIT> 5/23/087:57 AM EST
TMPGEnc DVD Author worked perfectly. I converted my .bin 1 and .bin 2 files to .mpeg in vcdgear, then fed both mpeg files to Tmpgenc. All played well without errors or sync issues, after being burned to DVD. Thanks Guns1inger, Your help is always appreciated!!!Seek, And You Shall Find.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
