I have a movie which is avi format. The movie is 2hours 26 minutes long, but when i use dvd flick to convert it to dvd, the end product is just a 35 KB file that lasts for 1 min 10 sec
Whats going wrong? I have used dvdflick to convert other movies, so why is this not working now
Thread: help with dvdflick
have you tried the latest dvd flick beta also? http://www.dvdflick.net/forums/viewtopic.php?t=534
If you have then give us more information about your source file, like a post screenshot from gspot.
How do I post a screenshot from gspot? And even so, what will that screenshot tell you?
[/img]
In regards to screenshots, follow the directions here: http://forum.videohelp.com/topic271697.html
Any information GSpot provides about the AVI might give us a clue as to why the video isn't being converted correctly. For example, maybe it's encoded in a way DVD Flick doesn't like. Or, the AVI could be corrupt.If cameras add ten pounds, why would people want to eat them?
I got it to work. Seems the installed copy of dvd flick was corrupt, so I uninstalled and reinstalled, and bingo
One more issue, when I load a title into dvd flick, and then go to project settings->Video and choose NTSC, or NTSC-film or PAL, what am I actually choosing? Cause the titles I have converted to DVD using the PAL setting play in my DVD player and so do the ones using the NTSC setting. However, when I go to another DVD player, neither types of DVD play? Whats with that
Being you live in the U.S, you will want to use NTSC.
problem with DVDFlick
By Bavafan in forum Authoring (DVD)Replies: 3Last Post: 16th Sep 2010, 11:29 -
need help with dvdflick
By shashgo in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2010, 00:24 -
DVDFlick Re-Encoding
By bolintx in forum Authoring (DVD)Replies: 15Last Post: 12th Aug 2008, 09:43 -
no subs. using dvdflick
By crashstorm in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2007, 10:46 -
Question about DVDFlick
By acid_burn in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2007, 05:43
