How do i fit 10 full length vids into a DVD 9? what software should i use? i can only fit 3-4 full length vids into it.
what should i do?
Results 1 to 19 of 19
Re-think your plan ?
You have three options
1. Use very low bitrates at standard resolution, producing low quality video
2. Use VCD resolution at standard to low VCD bitrates, and produce low resolution, VHS quality (maybe) video
Both options 1 and 2 will play on standard DVD players. Or
3. Encode the files to Xvid with AutoGK and burn as data. Playable on PCs and Divx/Xvid capable DVD players. This is the only option that will fit that amount of data without producing low quality video.
file size = bitrate * running time
RALMAO!!!
10???????????? that is plain nuts!!!!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
Maybe his "full length vids" are 22 minute TV shows.
even so, that is 220mins....still LOL even on DVD-9...not worth the effort....just buy another DVD-9 and forget about it.
booyah!!!!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
Is Kwag back?
This is reminiscent of the old "Put 7 hours of video on a VCD at high quality using KVCD!" posts that we used to get years ago.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
220 minutes = 3.5 to 4 hours. At 352x480 with a 2000-2500k VBR bitrate, 256k stereo, interlaced MPEG-2, with a GOOD ENCODER, that's really not an issue.Originally Posted by ron spencer
It's the same as "SP mode" on a DVD recorder (identical bitrate allocation, but for Half D1).
And on a DVD-5 (SL disc), yes.
MainConcept, Procoder, maybe even ConvertXToDVD. Author with TDA 3.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
been there done that....gross not worth the effort...poster already has one +r DL...get another one. They are super cheap on sale...verbatim.
this nonsense of half D1 is crazy, unless you watch on 10" TV'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
It's nice having the input of the person who is the final arbiter of what's acceptable and what's not for everone on earth under all situations!Originally Posted by ron spencer
hey its their time not mine...I don't care what they do....I just think with media so cheap why waste the effort?
LOL'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
I dare say that conditions in the Philippines are different from whereever Ish-ka-bibble is .Originally Posted by ron spencer
If minimal cost is the biggest consideration, I suggest VHS EP. Beats the hell out of any 1/2D1 mpg2 encode I can do that would put 8 hours of video on one DVD 9.
@bendixG15
if OP can afford a burner then can afford media, unless you infer there is a shortage of media in Philippines.....
BTW, Ish-ka-bibble is all around you!!!!!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
No, in the long run media is more expensive than a burner.Originally Posted by ron spencer
ron spencer ... suggest you GOOGLE Ish-ka-bibble and discover the true meaning of the word .. it is not a place...
and oh, BTW I don't know if there is a shortage of media in the Philippines
and I have no interest in the matter.
I can't believe you actually googled it!!!!
RALMAO....you made my day!!!!!
thanks!!!!!
@jagabo
if OP cannot afford media then why did they buy burner? If they did this they they are beyond help of any type....'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
Or if you can find them any where > DVD-18
Quote:
DVD-18 in an acronym that means a two-sided DVD disc with two layers of data on both sides of the disc -- in other terms, it is a two-sided disc ... in other terms, it is a two-sided disc that holds DVD-9 disc on both sides of it.
Now if I had those, Id be very happy doing my backups ... half the disc's
But seriously, Im looking more towards > http://www.dealsdirect.com.au/p/pion...-writer-drive/
people, routinely put 2hr movies on a sl dvd 4.5, so why not put 4 hrs on a dl dvd 9,Originally Posted by ron spencer
220 minutes yes, 420 minutes ( 10*42, 1hr shows ) NO !
his statemate about 3-4 vids calls into question, does he mean 3-4 hrs, or 3-4 movies or 3-4 episodes or what, how long is the run time ?
3-4 hrs on a DL for good quality, the term vids is ambiguous, the running time of the episodes is in question
avi not playing full length on DVD player
By David Banner in forum Newbie / General discussionsReplies: 9Last Post: 23rd Nov 2011, 15:21 -
mp4 video not playing for the full length in vlc player
By sumeshkri in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2010, 17:50 -
movie length into a avchd dvd9
By supersam in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Oct 2009, 00:42 -
VLC problem - doesn't display full length, only plays bits...
By MikeMGMVE in forum Software PlayingReplies: 3Last Post: 3rd Sep 2008, 14:38 -
Burning vcd/svcd full length film.........
By marcgarcia in forum Authoring (VCD/SVCD)Replies: 2Last Post: 15th Oct 2007, 20:07
