i have alot of anime i wanna backup and was wondering when i reauthor with dvd shrink i found that just doing the main movie and removing audi and subs not needed lets me fit it on a DVD-5 with no compression but i loose menu so my question is does it really matter if you leave the menu or not ??? besides having easy track selections
Thread: DVD Backup Question ?
when you go to the theater is there a menu before the movie?
At our Gold Class cinemas there is. I can order pizza and beer to arrive during the movie. But I don't think that is what you meant . . . .
Why not keep the menus in shrink for track selection ?
I'm sure the menu's take up less space than any of the extra audio tracks you removed 8)
(and i have to go get my own pizza and whiskey
Originally a member since 2001, LONG LIVE TARAN's!!!
You still have chapter/track selection taking "movie only"....you just need to use the correct button on your remote.Originally Posted by Azures
It's not really selecting a chapter....it's more like "next" chapter.
Greets,
Give DVD-RB a try and use the HCenc encoder engine with it. You can keep the working menu's, de-select audio and subtitle tracks you do not want. The free version should have most of the functions you need. The Pro one is well worth the money spent.
I can go either way with menu's. If it is a movie-only rip I will go without them. If ripping out half the episodes of a dual layer disc to put onto a single layer disc I might create my own menu with TDA. DVDShrink is a nice program but I use it more for reauthoring than for compressing content.
Cheers,
RickRene: Could you not just wound him a little bit?
Hans: Well now, with a 25 pound shell that is not easy.
'Allo 'Allo
DVR backup question
By khox054 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 10th Aug 2010, 16:03 -
DVD Backup Question
By rede96 in forum Newbie / General discussionsReplies: 7Last Post: 21st Nov 2009, 16:05 -
RAID-0 Backup Question
By Gromit137 in forum ComputerReplies: 19Last Post: 2nd Jan 2009, 06:47 -
backup question
By rcguy1 in forum Newbie / General discussionsReplies: 3Last Post: 5th Apr 2008, 12:16 -
Question about time it takes to backup hd-dvd
By ultraman36 in forum DVD RippingReplies: 0Last Post: 6th Dec 2007, 13:18
