I'm trying to split several video clips, one from a webcam and the others from a camcorder. Since they have different sizes, audio, etc., I'm converting them to a standardized format. Here's what I have so far:
Problem: the first video clip (from the webcam, framerate of 25.1, size 320x160, pixel format bgr24, audio sampling 44,100 ) plays the audio okay, but the video is speed up by what looks to be about a factor of 4.Code:c1=DirectShowSource("c:\avi\meetup\279.339.avi").Trim(0,500).BicubicResize(720, 480).ConvertToYV12().ChangeFPS(25).ResampleAudio(48000) f=c1 c2=DirectShowSource("c:\avi\meetup\280.339.avi").Trim(0,500).BicubicResize(720, 480).ConvertToYV12().ChangeFPS(25).ResampleAudio(48000) f=Dissolve(f,c2,45) f
The second clip appears to be okay, but need the two clips to be in a standard format for the dissolve.
Any suggestions on how to fix this? I realize my conversion efforts are somewhat a stab in the dark, and the audio adds even more complexity.
When I tried to resample the audio down to 11k, the audio was silent.
Thanks for any suggestions,
Tac
Thread: Audio Issues: Resampling, etc.
Perhaps process one file at a time, saving each one to a lossless codec such as huffyuv, then dissolve the resized AVIs afterwards.
I thought about (figuring it'd be easier to debug as well), but how can I put that in the script? That is, is there a way to save a clip to a particular format within the script itself?
Obviously, it's not that, but that's what I'm looking for, and am not even sure it's possible within aviscript.Code:a=DirectShowLoad('a.avi').Trim(0,500).ChangeFPS(25) a.SaveAsMPEG("a.mpg") # ???????
Thx,
Tac
You don't put it in a script. You open the basic script in VDub(Mod), choose a lossless codec (HuffYUV, Lagarith, etc), and encode the AVI. Do that for both video clips, and if they wind up with the same properties, create a new script for the AVIs using AVISource and do the dissolves or whatever else you want.
Losslees Audio on DVD player without resampling
By ITISRAVI in forum AudioReplies: 7Last Post: 22nd Jun 2011, 23:28 -
[Audio] Capturing, editing, keeping a/v in sync and dynamic resampling
By rmdeboer82 in forum CapturingReplies: 1Last Post: 20th Mar 2011, 14:16 -
Resampling audio
By siluet in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2009, 11:24 -
Resampling Audio
By Germanicus__ in forum AudioReplies: 18Last Post: 19th Jun 2009, 03:55 -
Audio sync issue even when dynamically resampling audio
By purpleman in forum CapturingReplies: 4Last Post: 19th Mar 2008, 10:18
Statistics
Newest guides
Latest tool updates
New media comments
