This is the first in a group of movies where I am receiving this error. It is a new movie. I processed it just like all my movies. First ran it through DVD HD DEcrypter, then through DVD Shrink then I started burning with IMG Burn and then get the error.
Here is the error message:
I/O Error!
Device: [0:1:0]_NEC DVD+RW ND-2100AD 103D (E: ) (ATA)
ScsiStatus: 0x02
Interpretation: Check Condition
CDB: 28 00 00 01 FC 20 00 00 01 00
Interpretation: Read (10) – Sector: 130080
Sense Area: F0 00 03 00 01 FC 20 0A 00 00 00 00 02 00 00 00 00 00
Interpretation: No Seek Complete
I 09:58:24 ImgBurn Version 2.4.1.0 started!
I 09:58:24 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
I 09:58:24 Total Physical Memory: 1,571,836 KB - Available: 1,009,796 KB
I 09:58:24 Initialising SPTI...
I 09:58:24 Searching for SCSI / ATAPI devices...
I 09:58:24 Found 1 DVD-ROM and 1 DVD+RW!
I 18:24:09 Operation Started!
I 18:24:09 Building Image Tree...
I 18:24:09 Checking Directory Depth...
I 18:24:09 Calculating Totals...
I 18:24:09 Preparing Image...
I 18:24:10 Checking Path Length...
I 18:24:10 Contents: 33 Files, 2 Folders
I 18:24:10 Size: 4,680,822,784 bytes
I 18:24:10 Sectors: 2,285,558
I 18:24:10 Image Size: 4,681,498,624 bytes
I 18:24:10 Image Sectors: 2,285,888
I 18:24:10 Operation Successfully Completed! - Duration: 00:00:00
I 18:36:09 Operation Started!
I 18:36:09 Building Image Tree...
I 18:36:09 Checking Directory Depth...
I 18:36:09 Calculating Totals...
I 18:36:09 Preparing Image...
I 18:36:09 Checking Path Length...
I 18:36:09 Contents: 33 Files, 2 Folders
I 18:36:09 Size: 4,680,822,784 bytes
I 18:36:09 Sectors: 2,285,558
I 18:36:09 Image Size: 4,681,498,624 bytes
I 18:36:09 Image Sectors: 2,285,888
I 18:36:09 Operation Successfully Completed! - Duration: 00:00:00
I 18:36:14 Operation Started!
I 18:36:14 Building Image Tree...
I 18:36:14 Checking Directory Depth...
I 18:36:14 Calculating Totals...
I 18:36:14 Preparing Image...
I 18:36:15 Checking Path Length...
I 18:36:15 Contents: 33 Files, 2 Folders
I 18:36:15 Size: 4,680,822,784 bytes
I 18:36:15 Sectors: 2,285,558
I 18:36:15 Image Size: 4,681,498,624 bytes
I 18:36:15 Image Sectors: 2,285,888
I 18:36:18 Operation Successfully Completed! - Duration: 00:00:03
I 18:36:18 Operation Started!
I 18:36:18 Source File: -==/\/[BUILD IMAGE]\/\==-
I 18:36:18 Source File Sectors: 2,285,888 (MODE1/2048)
I 18:36:18 Source File Size: 4,681,498,624 bytes
I 18:36:18 Source File Volume Identifier: GREAT_DEBATER
I 18:36:18 Source File Application Identifier: IMGBURN V2.4.1.0 - THE ULTIMATE IMAGE BURNER!
I 18:36:18 Source File Implementation Identifier: ImgBurn
I 18:36:18 Source File File System(s): ISO9660, UDF (1.02)
I 18:36:18 Destination Device: [0:1:0] _NEC DVD+RW ND-2100AD 103D (E (ATA)
I 18:36:18 Destination Media Type: DVD+R (Speeds: 2.4x)
I 18:36:18 Destination Media Sectors: 2,295,104
I 18:36:18 Write Mode: DVD
I 18:36:18 Write Type: DAO
I 18:36:18 Write Speed: MAX
I 18:36:18 Link Size: Auto
I 18:36:18 Test Mode: No
I 18:36:18 OPC: No
I 18:36:18 BURN-Proof: Enabled
I 18:36:18 Book Type Setting: N/A
I 18:36:18 Filling Buffer... (40 MB)
I 18:36:21 Writing LeadIn...
I 18:36:32 Writing Session 1 of 1... (1 Track, LBA: 0 - 2285887)
I 18:36:32 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2285887)
I 18:59:13 Synchronising Cache...
I 18:59:14 Closing Track...
I 18:59:25 Finalising Disc...
I 18:59:46 Image MD5: 34d8d4a1f69f8dc0fc231e8e88bfc1db
I 18:59:46 Operation Successfully Completed! - Duration: 00:23:27
I 18:59:46 Average Write Rate: 3,361 KB/s (2.4x) - Maximum Write Rate: 3,492 KB/s (2.5x)
I 18:59:46 Cycling Tray before Verify...
I 19:00:08 Device Ready!
I 19:00:11 Operation Started!
I 19:00:11 Source Device: [0:1:0] _NEC DVD+RW ND-2100AD 103D (E (ATA)
I 19:00:11 Source Media Type: DVD+R (Book Type: DVD-ROM) (Disc ID: OPTODISC-R16-00) (Speeds: 2.4x)
I 19:00:11 Image File: -==/\/[BUILD IMAGE]\/\==-
I 19:00:11 Image File Sectors: 2,285,888 (MODE1/2048)
I 19:00:11 Image File Size: 4,681,498,624 bytes
I 19:00:11 Image File Volume Identifier: GREAT_DEBATER
I 19:00:11 Image File Application Identifier: IMGBURN V2.4.1.0 - THE ULTIMATE IMAGE BURNER!
I 19:00:11 Image File Implementation Identifier: ImgBurn
I 19:00:11 Image File File System(s): ISO9660, UDF (1.02)
I 19:00:11 Read Speed (Data/Audio): MAX / MAX
I 19:00:11 Verifying Session 1 of 1... (1 Track, LBA: 0 - 2285887)
I 19:00:11 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 2285887)
E 19:08:38 Failed to Read Sector 130080 - Reason: No Seek Complete
E 19:08:38 Sector 130080 maps to File: \VIDEO_TS\VTS_06_1.VOB
E 19:08:38 Failed to Verify Sectors!
E 19:08:38 Operation Failed! - Duration: 00:08:27
I 19:08:38 Average Verify Rate: 514 KB/s (0.4x) - Maximum Verify Rate: 5,172 KB/s (3.7x)
According to the log it burned successfully.
Do not use verify,as long as the DVD plays it's ok.
BTW:your NEC is old and slow,it may be time to retire it. -
the media you're using isn't good quality,Disc ID: OPTODISC-R16-00
before buying a new dvd burner get some VERBATIM DVD MEDIA to use and if you get the same errors then it's time to buy a new dvd burner as MOVIEGEEK suggested. -
msdker,
The error is giving you a heads-up on a problem you're having...namely your 8x drive is burning 16x media at 2.4x, which is the only speed the drive says it can burn that media at. The drive's current firmware apparently doesn't have a write strategy for the media, and is falling back to the generic "gamble" write strategy, which is very unlikely to produce a good burn...if it works at all.
If you want to continue using that drive, you should check the system manufacturers website for your computer to see if they have updated firmware for the drive...or use older media (4x or 8x) that might have a valid write strategy in your current firmware.
To be honest, a new drive is much more likely to give you good performance with newer media like you have (and dual layer if you felt the urge). I just got a samsung sh-s202j from newegg for $24 with free shipping, so it isn't expensive...and it would make your burning much easier and trouble free. -
I just bought a Pioneer DVR-115D from MWAVE.COM for something like $25.99 + shipping. Very nice DVD burner at that
MOVIEGEEK was right. The movie plays just fine so I guess it works even when it says it doesn't.
I would try the Verbatims but when it seems to work fine on 90% of the movies I burn then I think I will stick with the stack I have until they run out then move to Verbatims.
I am sure that my drive is old as my computer is old too. I will have to look into a new one. -
msdker,
After you've used up your current supply of 16x media, you shouldn't buy any more 16x media (of any brand) while you're using your current drive. 16x media was designed for a different era of burners than the one you have, so your drive doesn't know how to burn it correctly. You should only use media your drive knows how to handle...in this case 4x or 8x media that was around when your drive was manufactured. As a bonus, not only will the older, lower speed rated media produce better burns, it costs less, and should actually burn faster. -
RIMA.COM has Taiyo Yuden 8x DVD-R media and Taiyo Yuden 8x DVD+R media. The price per 100 is only $25.99 + shipping for the 8x DVD-R discs and $32.99 + shipping for the 8x DVD+R discs.
I use the 8x DVD-R media myself.
IMG BURN windows error
By dereal in forum DVD RippingReplies: 1Last Post: 22nd Dec 2011, 17:36 -
DVD Shrink and IMG Burn
By tcory in forum DVD & Blu-ray WritersReplies: 10Last Post: 9th Jan 2011, 15:25 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
IMG Burn says - File too large!
By orfajackson in forum Newbie / General discussionsReplies: 6Last Post: 26th Jul 2009, 14:41 -
Which is best to burn - img, iso or video_ts
By dynamique in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2007, 15:13
