VLC player plays native HDV files from Canon HV20. But when I trim(shorten) a HDV file with TSRemux (saved as a TS file) then VLC will not play it. I get the following report: [main warning: received buffer in the future (282773051)main warning: vout warning: early picture skipped (282536013)) Nero will play it without a problem. I assume TSRemux is not setup to handle HDV. Is there a better scene trimmer out there that does not alter the original file quality? Or is there a setting on the programs I am using that will help? Thanks.
maybe TSmuxer ? http://www.videohelp.com/tools/tsMuxeR
Best app for cutting M2T files is VideoredoPlus
Update: TSmuxer solved the problem. I had to change the file extension from [.mpeg] to [.ts] for the program to recognize the original HDV file. The program properly cut the 10gb original movie into 4.5gb files (to store on DVD-ROM for mailing) and they play just fine with VLC. What great programs!
Also: I do have VideoReDo Plus but it does not work well with the HDV format. The output movie after editing runs choppy on both VLC and Nero 8. I'm not sure why yet. However - a great quick-unsexy way to edit HDV movies without altering the quality is to use HDVSplit to break your movie into seperate scenes, cut out the scenes you don't want (or shorten them with TSmuxer) then use the Joiner feature on VideoReDo to reassemble the scenes.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 6Last Post: 20th Mar 2012, 10:22 -
An M2TS file went thru TSRemux and has come without any file association
By mahogany in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2010, 09:04 -
can't play mp4 file on vlc player
By deadman1972 in forum Software PlayingReplies: 7Last Post: 15th Jul 2009, 10:42 -
VLC media player file?
By HartsVideo in forum Software PlayingReplies: 11Last Post: 19th Feb 2008, 13:42 -
What is the best /.m2t/HDV file player(s) for the PC?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 28th Sep 2007, 17:04
Statistics
Newest guides
Latest tool updates
New media comments
