VideoHelp.com Forum
    Which program do you prefer when authoring DVD-Video in linux?
    I am a new ubuntu 8.04 64-bit user and now I am trying to author DVD in linux.
    So I downloaded latest Q-DVDAuthor and made a manual install (instead of using synaptic which would give me an old version). However eveything seems to work until I press "make DVD" button and the subtitles are rendered, then the desktop goes black and restart itself so I have to log in to the desktop again.
    If I can't get QDVDAuthor fully working, then I will try some othe program for authoring.
    So that is why I ask, which program do you prefer when authoring DVD in linux?
    I want a program with possiblilities to add subtitles and different audio tracks and a simple menu to choose which movie to play.
  2. Man of Steel freebird73717's Avatar
    Have you tried running qdvdauthor from terminal to see what "if any" error messages pop up?
    Applications->Accessories->Terminal
    type qdvdauthor
    That should let you know what is happening "under the hood"
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
    No, I will try that. But will the terminal remain after craching the desktop, or can I save the terminal output to a file so I can restore the output after the crach? I am not used to working with the terminal.
    By the way, I noticed that directories or files with spaces in the name looked like separate directories in the terminal.
    For example using the file browser I can se a directory with name "DVD output" but in the terminal window it will lool like "DVD/ output". Is it recommended to avoid spacec in files and folders when working with linux?
    I found that using "" marks around the directory or file name works in the terminal:
    cd "/home/ronny/DVD output" works
    cd /home/ronny/DVD output does not work.
    This is similar as when working with a terminal window in WindowsXP.
    EDIT: qdvdauthor > output.txt
    The above should give me a log file output.txt
  4. Man of Steel freebird73717's Avatar
    Crap. Sorry didn't catch that it crashed your desktop. I thought I just read that it crashed the program. No terminal will probably not remain after desktop crash. You should be able to save the output of terminal to a text file but I'll have to do some digging to figure out how to do it.
    Yep quotes is the way to get around spaces in file/directory names.
    Another alternative is dvdstyler.
    Redirecting the terminal output to a file did not help because the file was empty after the crasch. But I solved the problem anyway because I remembered changig a setting of number of background threads from 0 to 3 because I was thinking my quad core CPU could use multiple threads. Changing this setting back to 0 solved the problem.
    Now I am amble to author a working DVD but the subtitles did not show up as I wanted (too small , not at bottom of picture and special swedish characters did not work) but now I can test different settings without craching.
  6. Man of Steel freebird73717's Avatar
    Good. Glad you got it worked out.
    OT I think I have auto-system shutdown figured out in HCbatchGUI GTK. If your interested I'll send you a preview via PM.
    Yes, I solved the subtitle problems too. The subtitle srt file was created on windows so the swedisch characters å,ä,ä,Å,Ä,Ö did not show up right on linux, but then I opened the text file with openoffice, selecting a working text coding and then saved it as standard text. If importing the converted text file the characters was OK and I also figured out how to change color, size and placement. Qdvdauthor seems to be quite an advanced authoring program after all but it is a little bit tricky to get used to all the options...
  1. LINUX: AVI to DVD Encoding and Authoring : BASIC
    By disturbed1 in forum User guides
    Last Post: 5th Feb 2010, 20:43
  2. DVD authoring - linux
    By andreltr in forum Linux
    Last Post: 24th Jun 2009, 12:58
  3. Replies: 5
    Last Post: 26th Nov 2008, 20:27
  4. usefull dvd authoring tools for linux
    By savignien in forum Linux
    Last Post: 12th Jun 2007, 04:21
  5. Replies: 0
    Last Post: 28th May 2007, 10:23
