hey i was wondering how i could make a new dvd menu from an already created dvd iso image?.. I was thinking just mounting the iso file and then import the dvd video_ts folder in TMPGEnc DVD Author 1.6 and create a new menu that way and re author it... what do u guys thing i should do?
Thread: create a dvd menu from iso image
If it's a "short" dvd then that's probably the straight-forward solution.
If your replacement menu will have the same number of buttons (and you only need to change the menu background or motion aspect of the menu), then you could author a "dummy" project with the new menu, and then use tools to replace the original menu (I Like PGCedit, some use DVDRemake Pro and other utilities).
Regards,
George
compare iso image with DVD/CD
By perfection in forum Newbie / General discussionsReplies: 14Last Post: 26th Jun 2011, 12:38 -
Help me create an .iso file from .vob dvd files!!
By SlyOne in forum DVD RippingReplies: 2Last Post: 15th Aug 2010, 09:25 -
How to create an ISO image file from a disc under UNIX.
By valeyard1492 in forum LinuxReplies: 11Last Post: 11th Sep 2009, 19:11 -
Cannot create ISO file with this type VIDEO_TS menu, Why ?
By RWANDREWS in forum Authoring (DVD)Replies: 2Last Post: 30th Apr 2008, 12:44 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
Statistics
Newest guides
Latest tool updates
New media comments
