Hello,
I was given a 1440x1080 footage that i have to work on ... and then export an SD DVD in pal 16:9
What do you recommend i work with in terms of sequence format in FCP?
If i use the 1440x1080 sequence format, what's the best export method to get a CLEAN SD PAL 16:9 video.
I made a test now, with this last option (HD 1440x1080 sequence) and exported it with compressor in DVD 90 minutes best - PAL 16:9 but the quality is not very good (blurry), what have i done wrong?
Thanks for any help,
regards,
kat
ok, i think i answered my own question:
in
FCP-> use sequence in original footage format
FCP-> Export Quicktime movie in original format
COMPRESSOR-> use the .mov produced by FCP and the DVD 90 minutes best preset
COMPRESSOR-> use the Dolby digital for the sound
DVD Studio pro-> use the .m2v and .ac3 files for the project and export an .img file
TOAST-> burn the img to DVD with video_TS preset
That how i could have the best quality ....
any best way? fastest way?
regards
k -
Originally Posted by katapulse
You could always export it in HD and then encode it using an encoder to an Standard Definition video formation. is that something u would intwnd to do?
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 01:10 -
Can't encode movie at 720 x 576
By zack28 in forum Newbie / General discussionsReplies: 14Last Post: 5th Jul 2011, 17:25 -
720 x 576 question
By higgins327 in forum Newbie / General discussionsReplies: 24Last Post: 31st Mar 2011, 14:44 -
720 x 576 (2703kbps bitrate) AVI for Archos 704
By drstew in forum Portable VideoReplies: 10Last Post: 31st Aug 2008, 13:49 -
dvd plays at 720 x 576 but when ripped goes to 352 x 576 and is squashed
By aljolson in forum Newbie / General discussionsReplies: 12Last Post: 8th Jun 2008, 11:54
