VideoHelp.com Forum
    My 3 yr old gateway laptop was dropped and the screen plasma now appears visually broke (physically all parts appear to work).
    I want to use the broken gateway laptop and send the video to my working ibm laptop just for the purpose of making sure the gateway computer is still working. I know how to do this if I had a plain monitor screen but I dont have a separate monitor. Is there a way I can do this using a second laptop or do I need to go out and buy a monitor.
    Please tell me if a second laptop works as the video display for a broken laptop. If so, how do I set this up?
    thanks,
    Joyce
    You can't unless your IBM laptop has video in. Very few have it by default, so the chances are very low. You really need an external monitor to check it out.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member yoda313's Avatar
    Or an alternative could be to use svideo out and hook it up to a tv with this input type. Then you can test it out that way. Of course it won't be nearly as sharp as a computer monitor.
    But your best bet is to pickup a real monitor. You would need a vga cable to connect it obviously.
    Thanks for your responses.
  5. Try using/installing remote desktop software. TightVNC would do it, as will the built in windows remote desktop, or perhaps use a free trial of internet based RDS services www.LogMeIn.com or www.GoToMyPC.com
  1. Laptop HP: No more display
    By themaster1 in forum Computer
    Last Post: 4th Jan 2011, 19:59
  2. Replies: 25
    Last Post: 13th Aug 2010, 06:04
  3. Replies: 4
    Last Post: 26th Jul 2009, 04:58
  4. Cannot change laptop's display resolution
    By edong in forum Computer
    Last Post: 5th Oct 2007, 14:06
  5. How to display RGBHV video on a Laptop Computer
    By Valinote in forum Capturing
    Last Post: 9th May 2007, 17:56
