VideoHelp.com Forum
Results 1 to 11 of 11
    I'm trying to split a DVD9 into 2 DVD5's with 100% quality using DVDFab but it crashes all the time. What other software can I try to do this? Thanks.
  2. Member hech54's Avatar
    DVDFabDecrypter - rip the complete disc....then use DVDShrink to split it. Works every time for me.
    Yes, like hech54 said, split it with DVDShrink, using the Re-author mode. It works quite well, and is faster and simpler than most other alternatives.
    Good Lord, I'd need a rocket scientitst to figure out this method!
  5. No, just a third grade education. Maybe that leaves you out.
  6. Member hech54's Avatar
    I don't like VOBBlanker either....to me it's like the Rube Goldberg of backup software.
  7. Maybe he wants to keep the extras and the menu. What good is DVD Shrink then?
    Using VobBlanker for splitting a DVD9 is simple. Most of that guide is for cleaning up the loose ends, stuff that isn't even strictly necessary. You open the DVD, blank the chapters in the 2nd half of the movie, and process. Then you open it again, this time blank the chapters in the first half of the movie (and any extras you kept the first time), and process. The guide is very detailed and covers all possibilities, but at heart it's an easy process.
    Yup, I've been using that method for a while now. It does the trick most of the time. Every now and then there are some movies that vobblanker can't do (at least I haven't figured out how to do them correctly), like those that use multi-angle stuff or that have theatrical and unrated cuts interleaved on the disc.
    I like this method because I get working menus on both discs and can keep whatever extras I want and put them on either/both discs. The guide doesn't go into detail about removing all the little 'intro' screens and stuff though, they're sometimes hidden in various cells, etc. That's one thing I've learned after getting a little more familiar with vobblanker. If you've got the time to try it out, it works great.
    I want NBC's Ed on DVD/Blu-ray!
  9. Member Super Warrior's Avatar
    Ya know using a program like DVDremakePro, you could just make 1 back-up with just the menu & movie, and then make another back-up with just the menu & extras.
    Or you could do both, but keep half the movie & half extras on one disc, with the second half on the other.
    Theres your two DVD-5's split with no compression. Nothing complicated here.
  10. Member ricoman's Avatar
    CloneDVD2 works fine for me.
    I love children, girl children... about 16-40
    W.C. Fields
  1. Replies: 6
    Last Post: 28th Feb 2011, 08:10
  2. Replies: 35
    Last Post: 6th Dec 2010, 08:40
  3. The best possible quality of DVD9 to DVD5
    By Charmer in forum DVD Ripping
    Last Post: 28th Apr 2010, 19:00
  4. Replies: 7
    Last Post: 9th Sep 2009, 05:50
  5. How to shrink DVD9 to DVD5 with no Quality loss?
    By CERO in forum Newbie / General discussions
    Last Post: 4th May 2008, 06:18
