VideoHelp.com Forum
    I'm using Fairuse Wizard 2.8 to convert a DVD series into MKVs with two language audio tracks. The MKVs contain x264-encoded video and a variable bit-rate MP3 for the audio.
    Since I don't want hard sub-titles burned into the video, the program is set to extract them, which results in two IFO and VOB files. How would I mux these into the MKV so I can turn them on and off when viewing?
    Thanks for any help.
    DOn't you get a idx/sub from fairuse wizard? or else try vstrip. Mux the subtitles into the mkv with mkvtoolnix.
    Greets,
    Mkvmerge (mmg) which is part the mkvtoolnix that Baldrick mentioned is great and fast. You can add in or remove audio tracks and subtitles how you like. MKV is a great container. VSRip to pull out the subs from your dvd and DGIndex to pull out the audio tracks.
    I prefer AC3 to MP3 for my audio because I can digi out the DD5.1+ to my home sound system's decoder. I've read of some units having probs with VBR audio but appearently that is not an issue with what you are doing.
    If you seek an alternative to your x264 encoder... I am a fan of AutoMKV, MeGUI and recently discovered XviD4PSP (don't let the name fool you) which is really nice as well. It only supports one audio track at the moment and hard codes the subs. That is no biggie, just use mkvmerge as mentioned above. An extra step or two for a quality vid that you will rewatch is worth it.
    Cheers,
    Rick
    Rene: Could you not just wound him a little bit?
    Hans: Well now, with a 25 pound shell that is not easy.
    'Allo 'Allo
    I tried again and finally managed to get the appropriate IDX and SUB files out of FairUse. They play perfectly when in the same folder as the MKV file, but I can't seem to get them muxed properly in mkvmerge. Would anyone have any advice on that process, or the MIME-type I should be using for the attachment?
    Thanks for all your help.
  1. Adobe Encore versus soft-subs and MKV
    By pc1971 in forum Authoring (DVD)
    Last Post: 3rd Jan 2010, 05:07
  2. Backup DVD to mkv with soft subs
    By rapaz in forum DVD Ripping
    Last Post: 23rd Dec 2009, 23:16
  3. Replies: 1
    Last Post: 24th Nov 2009, 01:44
  4. Replies: 4
    Last Post: 3rd Nov 2008, 04:12
  5. convert soft-sub MKV to hard-sub MPEG-2?
    By whatever911 in forum Video Conversion
    Last Post: 29th Jun 2008, 17:12
